jerky/sticky rendered footage VS11+
stormcab
processor: Intel Duo Core 2.2ghz
ram: 4GB
Video Card: ATI Radeon 512
Hard_Drive_Capacity: 500GB
Post by stormcab »
Recently my rendered clips have been coming out with random jerky/sticky bits. If I re-render they appear at some point else. This has only just started happening during the last 10 or so hours of rendering I have done. It is also worse on some footage, and hardly happens at all on other footage??
Here is a short example so you can see exactly what I mean -
http://www.youtube.com/watch?v=2oJBouzN4-4
(obviously best viewed in full screen)
I have rendered using the same settings I have always done, nothing has changed. I have tried doing the rendering on VS9 and VS11+, on two different laptops, one with Vista and one with XP - the same randomness. The last major issue I had with audio being out of sync was cured by uninstalling all VS programs from both laptops and reinstalling.
1)footage comes from DV transferred to the computer via firewire
2)rendered as -
PAL DVD 70%
Lower Field First
16:9
LPCM
8000
720x576
(SMART RENDER OFF)
I think that's everything, thanks for any response.
Post by Black Lab »
Are you rendering the same footage when you do the tests with the two laptops? If so, try using separate footage so we can eliminate the clips as the problem. (Use clips from a previous project that has rendered ok.)
Does the rendered project play ok in the VS preview window, or does it only happen after uploading to YouTube? What I'm seeing looks like a YouTube issue.
stormcab
ram: 4GB
Post by stormcab »
Youtube wasn't ideal, but I was hoping it would work. The most obvious bit of it that isn't youtube is 00.16-00.19.
I have tried the same bit of DV and converted in on both laptops to try, same result, but at different intervals. First time the jerkyness was at the beginning and second time somewhere in the middle (although the odd bit pops up here and there throughout).
The problem happens when it is rendered to PAL DVD, and the jerkiness is seen through every media player and on the TV when burned to DVD.
Post by Black Lab »
Like I said, I would try rendering dv clips that you rendered ok in the past, just to rule out a problem with your current clips.
Unfortunately from my workplace I am unable to view the YouTube video.
I have previously had problems with jerky clips - somewhat resembling a wrong field order (Which yours do not appear to be wrong) and eventually tracked down the problem to a loose IDE cable between the motherboard and the hard drive. Although the cable looked secure, a good push with the thumbs did the trick.
stormcab
ram: 4GB
Post by stormcab »
I have tried rendering a DV tape from about 3 years ago and still getting the jerky footage. I have experimented by rendering a particularly bad 10 second clip by changing the settings on few things. When rendered to WMV the footage is smooth, and then with PAL DVD I clicked on the "two pass encode" which seemed to work perfectly; although this took about 4 hours to render 20 minutes of footage!
Any ideas what is going on with my mpeg2 PAL DVD encoding? and what is "two pass filter"?
With regards to the led to the motherboard, I am using a laptop, and I have never touched the inside of a computer. Besides, the same results are happening from two laptops.
http://www.stormcab.com/
We could do with a bit more information about your 2 laptops.
You have Windows XP but which version and which service pack level.
E.g. Windows XP Professional Service pack 3.
Also your motherboard, video card and audio card.
I would suggest you download and run Belarc Advisor
Have you updated Direct X to the Latest Version
I have now been able to view your You Tube Video and can see it sort of freezes for a fraction of a second every now and again. Definitely not a field order problem but could be that you hard drive(s) may need defragmenting.
stormcab
ram: 4GB
Post by stormcab »
Thanks for info. I have downloaded that Belarc program and will put the details here after I run a defrag. I haven't done a defrag for a while, as I thought that my Norton 360 is set up to do it automatically.
Back soon
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
360 will do an auto defrag. Check to see if it is set up. Open Norton 360 Click "Settings" then "Tasks Scheduling" then next but last on the list make sure that "Disc Optimisation" box is checked. Click "Apply" then "Close".
Personaly I always used Windows Defrag as well, it will always tell you if defrag is necessary!
John Mitchell
stormcab
ram: 4GB
Post by stormcab »
I have done the defrag and it didn't do a thing. I have just rendered a DV tape I filmed about 2 years ago, and the first 15 seconds is choppy, then smooth (I don't know if there is any further choppy footage later as it would take the hour to watch it all). I ran a couple of little tests, first rendering the first 15 seconds, which came out smooth?? then a whole minute - the first 15 seconds of this was choppy again. I then rendered the first minute in VS9 and no choppiness?? I am going to render the whole thing in VS9 to see if there is any change there. I AM READY TO PULL MY HAIR OUT!
From Belarc -
Operating System System Model
Windows XP Home Edition Service Pack 3 (build 2600) Gateway 3525GB 53.01.01
Enclosure Type: Notebook
Processor a Main Circuit Board b
1.70 gigahertz Intel Pentium M
64 kilobyte primary memory cache
2048 kilobyte secondary memory cache Board: Gateway KBC K53.28.
BIOS: Phoenix W320.F05 10/08/2004
Drives Memory Modules c,d
1079.97 Gigabytes Usable Hard Drive Capacity
294.77 Gigabytes Hard Drive Free Space
Slimtype DVDRW SOSW-833S [CD-ROM drive]
FUJITSU MHT2080AT [Hard drive] (80.03 GB) -- drive 0, s/n NN53T5114CJC, rev 0022, SMART Status: Healthy
WD 10EADS External USB Device [Hard drive] (1000.20 GB) -- drive 1 1504 Megabytes Installed Memory
Slot 'M1' has 512 MB
Slot 'M2' has 1024 MB
Local Drive Volumes
c: (NTFS on drive 0) 76.60 GB 15.61 GB free
d: (FAT32 on drive 0) 3.41 GB 1.47 GB free
f: (FAT32 on drive 1) 999.96 GB 277.69 GB free
Network Drives
stormcab
ram: 4GB
Post by stormcab »
Well it appears that actually my VS11 is crap. At the time I thought it was VS9 as well, but have been rendering in VS9 and it is fine. So current issues I have with VS11 are 1-rendering to PAL DVD results in jerky footage, and 2-crashes when I add chapters before burning a disc. I am just going to use VS9 for rendering and VS11 for editing. I bought VS11 on eBay quite cheap, it appears to be a proper copy and has a code and everything, but has there been any issues with people buying copies on eBay which they have had problems with??
Anyway, thanks for trying to help, and check out my new movie -
http://www.youtube.com/watch?v=tj97jdCtwrc
There's known problems such as pirated copies, and freebie versions (SE, VE) being sold. One commonality with pirated software is the KeyGen supplied, to generate a product key or serial number. While I have purchased and sold items on Ebay, I never have or will buy software from there. It's not really much cheaper, considering the risk you're taking. They could even plant viruses in the software...
mitchell65
ram: 4Gb
I agree with Ron as far as Ebay is concerned. I very nearly fell for cheap software on Ebay once sometime ago and found it was a University student copying "educational Microsoft software". I informed the Vice Cancellor. never heard back but it made me very cautious. I did though buy my VS 12 from Amazon but that was only a tiny bit cheaper than Corel shop but it did come in a box with a manual which is I find more useful than the downloaded version of the manual.
John Mitchell
