Are we obliged to burn a DVD media everytime we want to watch a movie in All2HD? or there are some tips to fool WinDVD 9 and let it play a DVD folder with full options?
How to use All2HD from the hard-disk?
Moderator: lata
If I run a DVD from a DVD hard-disk folder using ifos and VOB files I can't use All2HD
- ram: 2 GB
- sound_card: Intel GMA 950
Just a suggestion, you can fool your computer into thinking it has a real DVD in a real DVD drive by using a "Virtual CD" program.
You would need to convert the DVD folder to an ISO - if it is a DVD you made yourself then burn an ISO file instead of or as well as burning to a hard drive folder. If you are making a copy of a real DVD then you will need some software to do the job.
click here for some links to Virtual CD software
lesterf1020
- motherboard: ASUS P8P67 DELUXE
- processor: Intel Core i7-2600
- Video Card: Amd HD 6970
- sound_card: Soundblaster X-fi Titanium
- Hard_Drive_Capacity: 3 TB
- Monitor/Display Make & Model: Acer AL2216W & Samsung PX2370
you are probably trying to enable All2hd while playing a DVD. That was possible before the patch but after the patch you have to stop the DVD to change your all2hd settings or enable/disable hardware acceleration. Also All2HD does not work in a dual monitor environment. It might be one of those.vegetaleb wrote:It seems crazy but now even the physical DVDs can't use All2HD![]()
In the settings the Hardware Acceleration option is greyed out so I can't even choose to disable or enable it!!! What happened????
I have a ATI 4850 and patch B14.119
"History does not repeat itself. But it does rhyme!"
