Flip video horizontally
pepegota
motherboard: ASUS TUF Z390-Plus
processor: Intel i9 - 9900k
ram: 64 GB
Video Card: GTX 1660 6GB
sound_card: On board sound
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Ben Q, "21" LCD
Corel programs: VS 2018, VS 2019, VS 2020
Horizontal Flip
Post by pepegota »
dalemccl
I placed all the files from the FXBench folder, that was installed on my computer into the corel\..\vft_plugin folder. Did you do that, or just leave it as installed outside of VideoStudio?
Hopefully that will do it.
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
but when I drag the Burger effect filter to a clip in the time line
But what you should see is a cube entitled "FX Bench". That's what you drag to the clip on your timeline. The circle with a diagonal line moves as you drag it to the clip. That circle with the diagonal indicates that you have "collected" the filter from the library! All the filters in the program have that symbol! In fact everything you drag to the timeline be it video clips, images, colors etc all have the same symbol when you drag them.
Yes all 13 files in the FX Bench folder need to be copied to the yftplug folder here:
C:\Program Files\Corel\Corel VideoStudio 12\vft_plug
John Mitchell
dalemccl
Post by dalemccl »
pepagoto,
yes, I copied all the files from the Burger FX Bench folder to the VS vft_plugin folder.
I wonder if it has anything to do with the fact I am running VS 12 with Vista Ultimate 64 bit. Maybe the plug-in doesn't work with Vista or with 64 bit (or the combination).
It's not something I would probably use very often, so it's not a big problem.
Sony XR-500V, VS Pro X2
It certainly works with Vista Ultimate 32 bit...
boxy
Re: Flip video horizontally
Post by boxy »
Well, I've been trying to install FXBench with VSX2 and not having any success. I tried copy and pasting the FX files into the Corel vft folder and they are there but still do not show up when I run VS X2.
I read about running FX as a stand alone.... How would I go about adding the horizontal flip to a clip in the timeline in VS X2?
Use VSX3 - it DOES have a flip filter.
boxy
Post by boxy »
Thanks for that reply. Can't say I'll be getting VS 13 though....
At one time I had BenchFX working with VS X2 because I remember it had it's own slot in the dropdown Filters menu. I recently did a system recovery on my computer and reinstalled everything. Now for some reason it's not working. :?
boxy
Post by boxy »
Very strange situation....
So I open a project on VS X2 where I used FXBench. I click on the filtered clip in the timeline and VS freezes and the program needs to close. I try it again. Same result. So again I manually move the fxbench.vft file into Ulead Filters folder - I tried yesterday without any success - and now it works!
Very strange indeed.....
erdna
motherboard: Gigsbyte H81M
processor: I7 4770
ram: 16GB DDR3
Video Card: Intel HD4600
sound_card: Intel display audio
Hard_Drive_Capacity: 1TB 7200rp
Monitor/Display Make & Model: Panasonic TX32cx600e
Post by erdna »
I think this FX Bench is not ready for HD (AVCHD). The image gets strongly distorted on horizontal and vertical flips (like desynchronized in analog TV). Did somebody else try the filters on HDV or AVCHD ffootage?
boxy
Post by boxy »
erdna wrote:Did somebody else try the filters on HDV or AVCHD ffootage?
That's what I used the horizontal flip on (HDV) and it worked fine.
