audio out of sync but only when played via media steamer
Posted: Sat Jun 13, 2009 5:48 am
I have just rendered a mpeg2 movie and have found that the audio is out of sych but only when I play the file via my WD USB my media streamer onto my HDTV. I have no Out of Synch (OOS) issue when I play the rendered file in either VS2 or with Windows Media Player, but when I copy the file to an external hard drive and plug and play the file via the WD media steamer onto my HDTV I get an OOS issue.
The properties of the rendered file are:
MPEG2-Video, UFF
24 bits, 1920x1080 16:9
25 fps
data rate = 28,000
audio type = MPEG2 audio layer 2 files
48000Hz 16 bit stereo
384kbps
I have a few other rendered files, with the exact same properties, that I have done exactly the same workflow and have not noticed an OOS issue with those files when played on my HDTV via the WD media streamer (although those files do not have as much 'talking' bits as the troublesome file).
The troublesome file has about a dozen clips in a row of people talking. It appears that as the file progressing the OOS issue becomes more obivous. If I pause the file then resume playing the audio appears to line up again but then slowly start to drift apart the longer the file is played.
Any suggestions?
MPEG2-Video, UFF
25 fps
data rate = 28,000
384kbps
Any suggestions?
