Upper/lower field first...no difference
erdna
- motherboard: Gigsbyte H81M
- processor: I7 4770
- ram: 16GB DDR3
- Video Card: Intel HD4600
- sound_card: Intel display audio
- Hard_Drive_Capacity: 1TB 7200rp
- Monitor/Display Make & Model: Panasonic TX32cx600e
When I put an AVCHD clip, containing pretty fast moving objets, on the timeline, then go to "Share" and "create disc", and choose for DVD HQ I get a perfect DVD, but whether the disc creating properties are set to upper or lower field first, I get the same pictures. Normal?
erdna
- ram: 16GB DDR3
If I understand what you are saying, I would not have thought so. If you start with UFF mpeg-4 and put this in the burning module, it will still have to be converted during the burning process. In other words, it is not DVD-compatible, so the box 'Do not convert compliant mpeg files' will not apply, whether it is ticked or not. It will be the burning properties in the window above that which will apply.
In your original post, you said you get a perfect picture regardless of what the "disc creating properties" are set to (i.e. LFF or UFF), so I assumed you tried both by manually changing those properties, including manually changing the field order from UFF to LFF. If you didn't do that, and the default Field Order setting in the Burning module remained UFF regardless of any other changes in the properties you may have made, then yes, it would always be (correctly) UFF in the final DVD.
erdna
- ram: 16GB DDR3
Indeed Ken, the AVCHD (mpeg4) clip has to be converted to mpeg2 for DVD, so the "compliant file.." makes no sense. But it is exactly in the window above that I changed the field order. I did this several times, and verified on a digital display and on an analog monitor. I always get the same result: smooth motion, and the same "mousetheets" on frame freezes
erdna
- ram: 16GB DDR3
erdna
- ram: 16GB DDR3
Not exactly jaggies, which to my knowledge occur on nearly horizontal lines, also known in still photography, and not known as an interlacing artifact I think. What I mean can you see in the third image in http://www.100fps.com/ mentioned as "mice teeth"
