I have been using an MPG. file to make a video with MP3 audio and fade effects here and there.
when i go to save the video in mpeg1 format it completes about 30 seconds (of like 5 min) and then cancels and says 'unable to load library'.
although the entire 'movie' plays when i press play on the timeline.
im really confused.
its always stopping at the same point. and sometime when i try and save with a different format the first 10 seconds is like just black and then the first 10seconds of the movie just repeats twice.
what can i do.?
i spent forever on it -_-
VSP. file wont save to actual video format.
ablinkvboxa
We need to know a little bit more about your problem, please read the Sticky¡¦ at the top of this forum regarding ¡¥posting¡¦
Ok
What version of VS are you using?
Mp3 files have caused problems and converting/using Wav files may be better.
¡¥Unable to load library¡¦
May be a corrupt library transition, try replacing the effects/transitions around the point where it fails.
You refer to Mpeg1 files.
What are you intending to do with the video, burn a DVD or use on the web?
You mention saving to different formats but don¡¦t give any details.
What are your original video properties and what are your render/create settings.
Ok
