no storage to save BB error message
Ilene
motherboard: Thimphu intel Z 170
processor: i7-6700K quad core
ram: 16GB DDR4
Video Card: 6GB NVidia GeForce GTX 980Ti
sound_card: envy audio AV - band and olfson 5.1 channel
Hard_Drive_Capacity: 550SSD+
Monitor/Display Make & Model: Dell Ultra Sharp 25" 2560x1440
Corel programs: VSX8 32 And VSX9 64 and VSX10 32
Re: no storage to save BB error message
Post by Ilene »
hi.. I'm getting the same error message in X10
"No strorage to load BB'
I get this every time I render a file... doesn't matter the file type or if I change the location/destination of the rendered file
these are not nested projects -- it happens with just one video clip on the time line. I've changed file types, and even tried to render just the audio and the same message comes up.
I had seen this once before and I deleted some libraries from video studio ( thinking maybe I had maxed out) --- but whatever I try not isn't working.
The file renders perfectly fine to the location I tell it to go... but the program locks up. So you have to manually shut it down thru the task manager, and restart
the problem is that the file renders but must get stuck adding it to the library and hence locks up
SOLUTIONS??
Hi Ilene
Some tests I performed may years ago seemed to indicate a corrupt library?
Have you tried resetting the library.
Before you mess about make a copy of the 20.0 folder.
C:\Users\Trevor\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\20.0
I would try Exporting the Library to create a copy, if that process completes without problems, then do a library reset.
and if things get worse, revert back to the original 20.0 folder.
Ilene
ram: 16GB DDR4
Post by Ilene »
I deleted some more files and some recent renders from the library and for now that did the trick. Maybe there is a limit?
Jack001
motherboard: ASUS Sabertooth P67
processor: Intel Core i7-2600K 3.4 GHz
ram: 12GB
Video Card: NVidia GeForce GTX 460
Post by Jack001 »
Ilene wrote:I deleted some more files and some recent renders from the library and for now that did the trick. Maybe there is a limit?
I had the same issue. I reinstalled the VS, imported video files into library and the message showed up again. Then I read about your case and also deleted many files that I recently added and it was the reason. Now the VS works correctly. It seems the VS has internal counter of maximal number of files and it was simply overloaded. Bad thing since I have to remove older files from the library to load new ones.
