However it will not appear when the template is used in DVD Workshop 2. There is no problem if the highlight image is added while in DW2.
Adding a Highlight Image
Coral
- motherboard: Asus P8P67 Pro Rev. 3
- processor: Intel Core i5 2400 Quad Core 3.1GHz Socket 1155
- ram: 8 GB
- Video Card: Gainward GT 520 1024 MB RAM
- sound_card: On Board
- Hard_Drive_Capacity: 500 GB X2
- Monitor/Display Make & Model: AOC 19 inch CRT tube
I have been trying to add a highlight image to a dvd template created in PhotoImpact. The image will work while it is being tested and will also show on the thumbnail.
Coral
- ram: 8 GB
Coral
- ram: 8 GB
Colobus eggsjj1805 wrote:How
Take a ready made template that contains highlight image. Deleat all the items including the highlight images. DO NOT SELECT ALL AND DELETE oterwise it will not work. Save the "blank" template for any later use.
When you use the template and you reach the final stage (Export), you will notice that the original thumbnail image belonging to the blanked template is still there. Click on Update Thumbnail and it will be replaced with the new image.
Just to check if the highlight image is going to work or not. Before exporting, move the mouse pointer over a placeholder and the highlight image should appear black. If not black it means that it is not working. However using the blank template it never failed.
The question still remains: Why can't a highlight image work on a New DVD Menu ? I have'nt botherd to check since the above described mehod is working.
Hey, Any news about Brian (Devil) ? Have'nt seen him at MURC for a long time too.
Coral
- ram: 8 GB
