Cannot import DVD
hanskru
- motherboard: Ultra Durable Gigabyte Technology
- processor: Intel Core i5
- ram: 4GB
- Video Card: NVIDIA GeForce 8400 GS
- sound_card: High Definition Audio
- Hard_Drive_Capacity: 500Gb
- Monitor/Display Make & Model: ASUS All i8n one
- Corel programs: Ultimate 2020 upgrade
Cannot import DVD
Hi VS frineds,
I cannot in the capture mode import a DVD made with VS x2.
I tried also to import another DVD same problem, salso with VS10.
The error mesage: Failed to read DVD information, error message 0x80040901(2305).
In the past I was able to import DVD's within various VS previous versions.
Any suggestion?
Brgds Hans
Any suggestion?
Brgds Hans
Hans
VS 5.0,6.0,7.0,8.0,9.0,10,12, X3, X4, X5, X6 Ultimate,X7 Ultimat, X8 Ult, X8.5 Ultimate,VS1018Ultimate, VS2019Ultilate,VS2020Ultimate
JVC Everio GZ GX1BE
JVC Everio GZ GX1BE
Exactly how are you trying to import?
Jeff
Dentler's Dog Training, LLC
hanskru
- ram: 4GB
Hi ,
I import in the capture mode thru Import digital media.
I did it in the past with other VS versions and no problems, so I am wondering
brgds Hans
brgds Hans
Hans
JVC Everio GZ GX1BE
JVC Everio GZ GX1BE
I've had this problem in the past. Here's the post on how I managed to get it fixed..
http://forum.corel.com/EN/viewtopic.php?p=101397#101397
- ram: 2 GB
- sound_card: Intel GMA 950
I Ron's fix doesn't work try this link - similar but alternative fault as the one mentioned by Ron.
Fix: Import DVD (VOB) Files DMF/VS/MSP
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Import DVD
Have you tried this way :
right click the library or timeline
In select a DVD title box--------"Insert DVD"
With DVD in your DVD drive, select that drive
Select import
In import DVD box.........tick all the chapters you want
Click import
They eventually end up in the library or timeline depending on which one was right clcked on .......................... Ken
Select import
Click import
hanskru
- ram: 4GB
cannot import DVD
Hi Guys,
was away a fwe days.
Videoman: I have LXDVDPARSER.dll version 1.1.21.157, 1,25MB.
sjj1808 I have h264vdech.dll 717 kb
Kenneth Veal I tried also your suggestion, but I got the samne error message as mentioned before.
So anymore suggetsions?
Brgds Hans
Brgds Hans
Hans
JVC Everio GZ GX1BE
JVC Everio GZ GX1BE
hanskru
- ram: 4GB
cannot import DVD
Hi Trevor,
it happens with all my DVD's. The DVD itself plays well on a DVD player, only to import it within VS I got this problem.
Thanks Hans
Thanks Hans
Hans
JVC Everio GZ GX1BE
JVC Everio GZ GX1BE
guardiansoulblade
hanskru
- ram: 4GB
cannot import DVD
Hi guys,
I continued solving this problem. I connected an external DVD drive to my system and than I could import DVD trhu VS in capture mode, import digital media.
So any suggsetion why I cannot import thru my system DVD drive??
Thanks brgds Hans
Thanks brgds Hans
Hans
JVC Everio GZ GX1BE
JVC Everio GZ GX1BE
- ram: 2 GB
Re: cannot import DVD
The obvious answer is a broken DVD drive.hanskru wrote:Hi guys,
Thanks brgds Hans
Try this link: DVD Burning / Playback issues
To take Steve's suggestion of a faulty burner one step further, you could take out the burner in your computer and install it in the case of the external burner you successfully used. Then you could test it as an external burner. If it fails again, you would thus confirm that it needs replacing.
Conversely, you could swap the external and internal drives, and if the former external burner no longer works when it is internal, then there must be some other hardware problem...
