Unable To Load Library???
RayBaker
Post by RayBaker »
I'v created my first video project, and I wanted to render it
as a DV-AVI file...
So, I went to SHARE, then to CREATE VIDEO FILE, and selected DV...
Tried it three times, and each time when the progress meter came
to exactly 51%, I got the message:
"Unable To Load Library" With the numbers [19151:3:3}
The only option was to click OK, and VS canceled the render..
The I tried the YouTube Upload... Chose "CREATE .flv FILE"
VS began to render the file, then, exactly at 51%, crashed,
froze and stopped.... No message, no nothing...
I had to reboot my computer... I tried this one twice with the
same results...
Any ideas on what is wrong here?
Here re my capture settings...
Using VS x2
AVI (DV) NTSC drop frame (29.97)
Microsoft AVI files 24 bits, 720 x 480, 4:3, 29.97 fps Lower Field First
DV Video Encoder - type 1
DV Audio - NTSC, 48.000 kHz, 16 bit, Stereo
Here are my system stats:
OS Name Microsoft Windows XP Home Edition
Version 5.1.2600 Service Pack 2 Build 2600
OS Manufacturer Microsoft Corporation
System Name RAY-6YWN5IGXB25
System Manufacturer Gateway
System Model 310 2900494
System Type X86-based PC
Processor x86 Family 15 Model 2 Stepping 9 GenuineIntel ~2799 Mhz
BIOS Version/Date Intel Corp. SR84511A.15A.0014.P02.0307230940, 7/23/2003
SMBIOS Version 2.3
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)"
User Name RAY-6YWN5IGXB25\Ray Baker
Time Zone Central Standard Time
Total Physical Memory 512.00 MB
Available Physical Memory 196.39 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 1.20 GB
Page File C:\pagefile.sys
The first thing I would investigate is what is located about half way through your project since it consistently crashes at that point. It may be an audio file inserted there which VS does not like. If it is an MP3, try converting to WAV. Sometimes VS has problems with some transitions. Try removing a transition located at that point. Are all files used in your project still accessible by VS? Are there any inserted files, that are on removable media such as CDs, or external hard drives that have been removed are not connected?
RayBaker
Post by RayBaker »
You've touched on a number of things I have corrected,
and still, no luck...
First,... I do have an "external" hard drive, and some of my
files were stored there... So...
I first moved and relinked all the files in my project to my
main drive, and disabled my external hard drive...
Second... I increased the sizes of my virtual memory;
somewhere I saw that might help the above error...
Third.. I stopped "all" running services, like my virus protection, etc.
Upon rendering, same old same old, right at 51%
I didn't think about the transitions causing problems however,
so, your suggestion will be my next course of action.
I "do" have about five transitions, in close proximity, all
happening at once in my project... So.... I'm going to try removing
all the transitions at that point, just letting the images "bang"
into one another, and see if that helps...
Thanks for the suggestion, I'll let you know how it turns out!
RayBaker
Post by RayBaker »
vidoman wrote: Try removing a transition located at that point.
Hi Vidoman...
Success! It rendered! The project is completed!
It WAS a transition causing the problem; "BAR-ROLL"
I don't believe it was the transitions fault, probably the placing
of it, next to certain objects that caused the problem.
But anyway, it's done, and complete, and I send out special thanks
to you for your kind help.
If you or anyone want to check out my first video, here is the
YouTube URL
http://www.youtube.com/watch?v=UikOvk8fJhs
Go Brazil in 2012 @ The Olympics!
