Animated GIF's
RayBaker
Animated GIF's
Post by RayBaker »
Why is it, that when you insert an animated GIF into VS x2,
You do NOT see any motion?
I have tired inserting a number of animated gif's from different
locations, and none of them have any motion!
You have to install the animated GIF as if it were a video and not an image.
RayBaker
Post by RayBaker »
sjj1805 wrote:You have to install the animated GIF as if it were a video and not an image.
Hummm, yes, I thought that too...
When I tried to insert the animated gif in the video track, by dragging,
and by using, "insert" VS totally crashed each time...
Now, that's a good one, isn't it???
When wanting to use animated GIFs, as video clips you must bear in mind the properties. If the file only has 5 frames, and your video project is the standard 29.97fps or 25fps you're not going to see much if any animation. So make sure that your GIF file has a sufficient duration/frames. For an animated GIF to play as a video, it will need those numbers of frames for each second of play. Most animated GIFs are designed for web play, so have very few frames...
rwernyei
Post by rwernyei »
Corel software needs Quicktime installed on your system to use animated GIFs.
RayBaker
Post by RayBaker »
rwernyei wrote:Corel software needs Quicktime installed on your system to use animated GIFs.
But I "do" have QuickTime installed on my system...
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Post by rguthrie »
Ray,
Perhaps you misunderstood Steve when he said that you need "to install the animated GIF as if it were video." Here's how I successfully inserted an animated GIF into a video.
Click on the Insert media files into the Timeline icon (that the folder with the arrow pointing down). Next select, Insert Video. Now for Files of Type, select Animated GIF Files, and select your animated gif file. Viola!
Hope this helps,
SFC (Retired) Ronald Guthrie (aka Alt0S4x)
VS4SE/6-11.5+/X2-X10 Ultimate/2018-2023, Pinnacle Studio 25; Ultimate; MotionStudio 3D; PI11/PIX3;Corel PainterEssentials 4
Photoshop CS5; Audacity; SonicFire Pro 6.0
Wacom Bamboo Fun Tablet
Canon Rebel T4i
RayBaker
Post by RayBaker »
Thanks for the tip Ron...
However, even trying your method, every time I try to
insert an animated gif into VS x2, it crashes...
I mean, it just quits the program, and VS is gone...
Strange one, huh?
rguthrie
ram: 64GB
Post by rguthrie »
Ray,
That is indeed strange. Can you post the properties of your gif?
Ron
Canon Rebel T4i
metmot
motherboard: Asus M2N SLI
processor: AMD Athlon 64 x2 Dual Core 6000+ 3.0 gh
ram: 8 GB
Video Card: Nvidia Gforce 7300se
sound_card: Onboard PnP Sound Device
Hard_Drive_Capacity: 1.7 TB
Post by metmot »
RayBaker wrote:Thanks for the tip Ron...
Strange one, huh?
Not that strange. I have had very similar unexplainable experiences with VS crashing with various MPEG 4 files. Certain files I cannot insert, period. Others with seemingly identical properties work.
Hmmm.
John
