How to adjust Audio to sync with video?
Posted: Thu May 21, 2009 5:52 am
by TedJohnson
I thought that I remembered reading this somewhere on the forum, but now that I need the info, I can not find it.
I have an mpeg video file which has the audio out of sync with the video. I think that all I need to do is somehow advance the audio about 200 milliseconds to get it back in sync. Is there a method to do this in videostudio? I assume that someone here has already gone down this path.
I have both 11.5 and X2 Pro. Mpeg (mpeg2) file is approx 59 minutes long.
Thanks in advance for your help.
Ted
Posted: Thu May 21, 2009 11:35 am
by jparnold
Have a look at the following -
Audio / Video synchronization issues
Posted: Thu May 21, 2009 12:57 pm
Yes, you click on the audio track and move it. I'd say about 200 milliseconds or so. :wink:
Seriously, do you want to give us some details of your clips, where they are from, the properties of your project, and your workflow? Out of sync audio should not be happening.
Posted: Thu May 21, 2009 3:20 pm
by TedJohnson
The video is OOS NOT becasue of videostudio. It is a TV recording and the broadcast was transmitted OOS. I am attempting to use videostudio to adjust the synchronization. The transmission was captured with a Panasonic DMR-EZ47V which has always been, and continues to be, rock solid for this application. I just do minor editing, and then author. I have not yet edited the clip at all; thought it best to sync the audio first.
File specs:
NTSC
MPEG files
24 bits, 720 x 480, 29.97 fps
Upper Field First
(DVD-NTSC), 4:3
Audio data rate: 224 kbps
MPEG audio layer 2, 48 KHz, Stereo
Hope this helps
Thanks,
Ted
(Sorry, but I am off to work now with no access until tonight (PST), so my replies will be suspended until then. All help is greately appreciated, and thanks to all.)
Posted: Thu May 21, 2009 3:25 pm
If it was broadcast OOS then I think your only solution is to split the audio and move it until it is synched up.
Posted: Sun May 24, 2009 4:40 am
by TedJohnson
Thanks for your replies!
I have split the audio, and have been able to advance the audio track.
In doing so I discovered that the audio is already ahead of the video (go figure!?!). Anyway, I can not seem to move the audio track backward (I'm sure that is the wrong terminology). At any rate I need to advance the video ahead relative to the audio track, but I have not been able to figure out how this is to be accomplished.
Any suggestions? Or is this not possible?
Once again, many thanks
Ted
Posted: Sun May 24, 2009 12:14 pm
1. insert a black colour clip.
2. Insert the OOS Video clip.
3. Split the audio from the video.
This now gives you room to manoeuvre and you can shift the audio left or right as required until you are able to synch the audio correctly.
Posted: Tue May 26, 2009 4:57 am
by TedJohnson
Thanks Steve. Apologies for not getting back to you sooner; but I was out of town.
Ted
