I thought that I remembered reading this somewhere on the forum, but now that I need the info, I can not find it.
I have an mpeg video file which has the audio out of sync with the video. I think that all I need to do is somehow advance the audio about 200 milliseconds to get it back in sync. Is there a method to do this in videostudio? I assume that someone here has already gone down this path.
I have both 11.5 and X2 Pro. Mpeg (mpeg2) file is approx 59 minutes long.
Thanks in advance for your help.
Ted
How to adjust Audio to sync with video?
TedJohnson
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
Have a look at the following -
Audio / Video synchronization issues
John a
Yes, you click on the audio track and move it. I'd say about 200 milliseconds or so.
Seriously, do you want to give us some details of your clips, where they are from, the properties of your project, and your workflow? Out of sync audio should not be happening.
Jeff
Dentler's Dog Training, LLC
TedJohnson
The video is OOS NOT becasue of videostudio. It is a TV recording and the broadcast was transmitted OOS. I am attempting to use videostudio to adjust the synchronization. The transmission was captured with a Panasonic DMR-EZ47V which has always been, and continues to be, rock solid for this application. I just do minor editing, and then author. I have not yet edited the clip at all; thought it best to sync the audio first.
File specs:
NTSC
MPEG files
24 bits, 720 x 480, 29.97 fps
Upper Field First
(DVD-NTSC), 4:3
Audio data rate: 224 kbps
Hope this helps
Thanks,
Ted
(Sorry, but I am off to work now with no access until tonight (PST), so my replies will be suspended until then. All help is greately appreciated, and thanks to all.)
File specs:
NTSC
MPEG files
Upper Field First
(DVD-NTSC), 4:3
Hope this helps
Thanks,
Ted
If it was broadcast OOS then I think your only solution is to split the audio and move it until it is synched up.
Jeff
TedJohnson
Thanks for your replies!
I have split the audio, and have been able to advance the audio track.
In doing so I discovered that the audio is already ahead of the video (go figure!?!). Anyway, I can not seem to move the audio track backward (I'm sure that is the wrong terminology). At any rate I need to advance the video ahead relative to the audio track, but I have not been able to figure out how this is to be accomplished.
Any suggestions? Or is this not possible?
Once again, many thanks
Ted
Ted
TedJohnson
