Required disc space greater than disc space available?
Posted: Sat May 16, 2009 9:06 pm
I am new to the Forum and I am very impressed with its quality and professionalism. I purchased VSProX2 two months ago but I am not new to video editing (started with Pinnacle but switched to Ulead because of frequent Out of Sync problems, then upgraded to VSProX2 recently; to date I have successfully edited about 8 full-fledge videos of trips made with a duration of 1:30 to 2:00 hours each with mainly photos and some videos inserted).
Per your instructions I spent the last couple of days reading extensively the manual and many postings and tutorials (like workflows) to avoid posting already covered topics but still have questions all related to above topic for which I could not find an answer:
1. In ¡§Create Disc¡¨, what does the green/yellow/red bars really mean and do to the video in the ¡§Required disc space¡¨ (I know intuitively that it should be like the bars in a burn program like Nero but it acts differently per my next questions) ?
2. Why a yellow bar if the green represents the maximum available disc space and red indicating that we exceeded it ?
3. Why does it at times burn successfully to a disc even with yellow and red bars ? (I did burn a 1:34hr VSP project video successfully on a 4.7G disc even with yellow and red bars)
4. What does the Gb numbers in brackets mean versus the preceeding number ? (above video of 1:34hr showed required space 2.97Gb (3.28Gb) at beginning of green bar and available space 4.38(4.70Gb) at end but with a yellow and a red bar)
5. If it did burn successfully even with yellow and red bars, it must have ¡§fit to disc¡¨: I guess my quality was degraded even if my project properties still show a DVD quality of 640x480 ?
6. Per your workflow suggestion, I then decided to create my new trip video on VSProX2 using the ¡§Create video file¡¨ first (.mpg), then open VSProX2 in ¡§Create disc/Open file¡¨ and added a simple menu (2Mb according to program) to end up on a 8.5Gb dual layer disc with 7.89(8.47Gb) required with green bar (layer 1 & 2) and a yellow bar even with 7.96(8.55Gb) available disc space indicated at end of bar; why the yellow bar if it fits ?
7. I tried the same .mpg file by inserting it in the timelime instead, then did ¡§Create disc¡¨ and added the same menu (2Mb) and it showed only a green bar (layer 1&2) with 6.37(6.84Gb), so much less space required for the same .mpg file though compliant): why ????
Help please as I don¡¦t understand the logic here !
Thanks !
Thanks !
