VS 10 SE - Importing All Movie Files Into Library?
Posted: Fri May 15, 2009 9:15 pm
by RayBaker2009
In VS 10 SE, is there a way to import or batch insert 10 or 20
different videos into the library of VS; at one time, and in one shot?
I have been clicking on each video separately to into insert it in the library...
Tedious¡K
There must be an easier way...
Posted: Sat May 16, 2009 1:02 am
Are you talking about files that are already on your computer? When you click the Insert button and navigate to your files click on the first clip, then Shift+click on the last clip. This will select all the clips in between. You can also use the other common Windows procedure of CTRL+click to choose non-sequential clips.
Posted: Sat May 16, 2009 1:29 am
by RayBaker2009
Thanks Jeff, exactly the tip I needed...
Why couldn't I think of that one?
A senior moment for me, I'm sure...
Black Lab wrote:Are you talking about files that are already on your computer? When you click the Insert button and navigate to your files click on the first clip, then Shift+click on the last clip. This will select all the clips in between. You can also use the other common Windows procedure of CTRL+click to choose non-sequential clips.
