VS 10 SE - Importing All Movie Files Into Library?
RayBaker2009
Post by RayBaker2009 »
In VS 10 SE, is there a way to import or batch insert 10 or 20
different videos into the library of VS; at one time, and in one shot?
I have been clicking on each video separately to into insert it in the library...
Tedious¡K
There must be an easier way...
Ray Baker
Post by Black Lab »
Are you talking about files that are already on your computer? When you click the Insert button and navigate to your files click on the first clip, then Shift+click on the last clip. This will select all the clips in between. You can also use the other common Windows procedure of CTRL+click to choose non-sequential clips.
RayBaker2009
Thanks Jeff, exactly the tip I needed...
Why couldn't I think of that one?
A senior moment for me, I'm sure...
Black Lab wrote:Are you talking about files that are already on your computer? When you click the Insert button and navigate to your files click on the first clip, then Shift+click on the last clip. This will select all the clips in between. You can also use the other common Windows procedure of CTRL+click to choose non-sequential clips.
Ray Baker
