pixelating
Posted: Sun May 10, 2009 1:21 am
by brianchew
I have a simple problem. I use VS 8 to pull
out commercials.My computer crashed so I reinstalled.Ever since then
when I put the footage in and start the rendering process, the
finished product tiles every once in a while. im recording with
Beyond TV at the highest quality so it has to be VS. Is there a
default setting in the preferences that is causing this that I need to
check or uncheck??
Posted: Sun May 10, 2009 3:02 am
by Clevo
Check your master footage from Beyond....sometimes when the TVsignal drops slightly you will get pixilation. Compare the master to the copy.
Posted: Sun May 10, 2009 4:15 am
Please view the following links:
Please read this before posting
and
Suggested workflow by sjj1805
Please click here --> Image so that we can then view your system specifications.
Hopefully you are NOT using Microsoft Vista - VS8 as quite an old program and I doubt it will work with Vista.
