When using Video Studio X2 for editing everything works fine. However the final result is not so good. I use smart rendering and the "un-touched" video is perfect.
But the newly rendered parts (like transitions, titles) aren't. They are treated as interlaced material. When looking at the options when creating the final movie,
you can only choose Upper Frame of Lower Frame. Not a full frame. So the parts that need to be rendered are treated as interlaced.
Resulting in the following effect:
Full frame: http://x68.nl/vlcsnap-6408.jpg
I have tried to find a solution. Even did extensive digging in the profiles. (Like "DF_TMPL_AVCHD_PAL.dat").
But couldn't make heads or tails from it. I hoped I could find some kind of parameter which would allow me to select full frame instead of upper/lower field.
I hope the problem is clear and I explained it correct.
Does any one have a good solution?
* Remark
When you are using the same kind of footage as I and you do not see this effect (very visible with up or down scrolling text). It may because most players
will automaticly deinterlace. When deinterlacing is turned off. It will be very visible.
Windows XP, 4GB, Core2Duo, GF8800.
Software: Video Studio X2
Camera = Canon HF100
Movies are recorded at 1920x1080 at 25p (progressive)
Players used: MPlayer Classic HC, VLC (deinterlacing deactivated)
