failed to reuse converted cache file when trying to burn dv.
gilliandell
Post by gilliandell »
I use VisualStudio 9.0
I try to create a dvd disk from several avi files.
After creating a disk, adding files and editing I go to the final step, burning, and then I get the message:
Failed to reuse converted cache file!
Report ID 0x800411da(4570).
On VisualStudio 7.0 and 8.0 it works fine.
Any suggestions?[/b]
jchunter
Post by jchunter »
Your procedure suggests that you are not following the one recommended in the top post. Try that first.
John
gilliandell
What do you mean?
Where can I find the recommended procedure?
Gillian
jchunter
Post by jchunter »
The procedure that has been shown to have the greatest success rate is printed in the sticky post at the top of this forum.
John
gilliandell
Thanks,
I followed the procedure and now I don't get the :
Instead when I hit the burn button I get:
Convert step got some problems! (4101)
Gillian
jchunter
Post by jchunter »
Gillian,
The magic word is "Converting." You should never be "converting videos" in the Burn phase. If you follow the procedure exactly, this should not happen. Is your timeline really empty when you SHARE/Create Disk? Are you Custom setting the Burn properties to match your Video File properties?
If so, please list your video capture properties, your project properties (when editing), your property settings when you SHARE/Create Video File, and your property setting when you SHARE/Create Disk. Also, what are your computer specs?
John
gilliandell
Thanks for the help,
I've had enough with VS9, I have VS7 and 8 installed and I've never had this kind of problem with them.
Basically I'm doing the same thing with all the version, but VS9 keeps making problems.
Thanks,
Gillian
