VideoStudio 11.5 Plus 1080p support?
Pixelation5
Hi all,
I own VideoStudio 11.5 plus and planning to buy a digital video camera soon that records at 1080p, and was wondering if VideoStudio 11.5 Plus supports editting this format?
Also, I have a 4:3 CRT monitor that does not support 1080p, is it possible to edit 1080p content from my computer?
My CPU is a Pentium 4 HT 3.2Ghz and I have 2GB of PC-3200 RAM. Would my system cope well with editting?
Nik
Nik
Welcome to the forums,
VS11.5+ can edit the Hi-Def formats, however if your 1080p camcorder records in the AVCHD format, then your PC might not be able to handle it. To edit AVCHD it is recommend to use a Quad-Core PC. VS has Smart Proxy for dealing with some of these very highly compressed HD formats, however even with that, a very powerful PC is required. It takes a very long time just to create the proxy file(s).
Pixelation5
Depends what model camcorder it is.
Jeff
Dentler's Dog Training, LLC
Pixelation5
Jeff
That should not be an issue. Your video driver will translate the pixel resolution, aspect ratio, and framerate. This won't affect the actual editing, which is done via the CPU.I have a 4:3 CRT monitor that does not support 1080p, is it possible to edit 1080p content from my computer?
I don't think so. (Last time I searched corel.com for CUDA, I only got forum hits.) And, with all of the different video formats & format variations, encoding/transcoding can be "difficult" (unreliable), even with the "old" CPU method. So, I think reliable encoding/decoding that uses CUDA would be limited to a few formats.Is it possible to get VideoStudio to call upon the processing power of my GPU, like CUDA?
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
I bought Video Studio X2 for editing my Canon HF100 footage. I capture my recordings in 25p format 1920x1080.
I use smart rendering when doing so, and only the transitions, titles, etc are rendered again. Here is the catch. They are rendered as interlaced video. When playing the created video you can there for see the interlaced effect in the transitions and titles. Especially with titles which scroll up or down.
So basicly: Video Studio X2 doesn't support 1080p AVCHD.
I have addressed this issue to Corel, unfortunately they do not have a solution for this (yet). I will start a separate topic regarding this issue.
You can however export it to MPEG2. Then you have can export your footage as 25p, but than there is no smart rendering and all frames are re-rendered. From my few this is a very poor work around which I will not use.
EDIT: Didn't look closely enough. My version X2 is version 12, you where asking about 11.5. I don't know for sure if it has the same limitations.
Depends on the format. DV-AVI is lossless and will not suffer quality loss when re-rendering. MPEG-2 is a lossy format and you may notice quality loss after several re-renderings. With other very compressed formats you may notice quality loss after only 1 re-rendering.
Jeff
Coral
- motherboard: Asus P8P67 Pro Rev. 3
- processor: Intel Core i5 2400 Quad Core 3.1GHz Socket 1155
- ram: 8 GB
- Video Card: Gainward GT 520 1024 MB RAM
- sound_card: On Board
- Hard_Drive_Capacity: 500 GB X2
- Monitor/Display Make & Model: AOC 19 inch CRT tube
Coral -- you can, of course, burning high definition video onto a standard DVD using the AVCHD format. This makes it a 'hybrid disc' and it can only be played on a Blu-Ray player rated to play hybrid discs. You can use either HDV or AVCHD source video, and even make a menu for it in VS. But it is of course not a standard definition video DVD...
Pixelation5
That's unknown, probably not (yet). However if you want to do a little research on why this current format poses problems, Google AVCHD.. here's a start..
http://en.wikipedia.org/wiki/AVCHD
AVCHD and the AVCHD logo are trademarks of Panasonic corporation and Sony corporation
I found this suggestion on another forum, where the question in using CUDA along with a competitor's NLE program. It was recommended to use TmpGenc4. http://tmpgenc.pegasys-inc.com/en/product/te4xp.html
or Grass Valley FirecoderBlu
