Cannon Hard Drive Cam and VS11
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
Re the above some advice please on the following :-
1 Capture Format
2 Audio format in project options
3 project properties edit file format
4 Audio and Video format in Compression tab
5 Anything else to look for
I want to edit the project and burn a PAL DVD from it (XP) ...........Ken
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
Have you tried this:
http://forum.corel.com/EN/viewtopic.php?t=13421
I think it will answer all your questions
John Mitchell
Post by Trevor Andrew »
Hi Ken
As far as I know your video files are recorded to the hard drive on the camera.
These files are uploaded/copied to your hard drive on the pc.
Probably best to use the cameras software to do this.
No re-coding takes place, you are simply transferring the footage to the pc.
Then insert the file to the Video Studio timeline.
If you have Preferences- Show messages......... ticked, you should get the info window asking you to change the project settings to match.
Select ¡¥Details to view the right panel for the video properties.
Now select ¡¥yes¡¦ to match the settings.
(Hopefully you will see this window.)
Edit the project then create a new video file Share Create Video File ¡VSame as first Clip or Project settings.
Using the new file to burn a DVD. New Project Share Create Disc¡XAdd Video.
