Black Lab wrote:
Did you try Corel's suggestion of making on single clip?
As you say, rendering each clip would be very tedious. But are you going to put a transition between each and every clip? If not, the single clip variety might work. Try cutting the one large clip only where transitions are needed, then add the transition. Is the blip still there?
I did a brief test with 3 clips today using the work-around. The blips did not occur. I tested using these steps.
1. Place original camcorder AVCHD clips in the time line.
2. "Share/Create Video File/AVCHD" with quality set to 100% and bit rate to 18,000. Smart render off.
3. Place the resulting file in the time line of new project.
4. Cut the clip where I want to place transitions ( a little tedious to find the exact frame for cutting). Add the transitions.
5. Share/Create Video File/AVCHD with quality set to 100% and bit rate to 18,000.
The file output by step 5 did not have blips. However, as expected, it was of lower quality than the original clips. It lost that quality in step 2. The original clips' bit rate was 15,000-17,000 bps. The file created in step 2 had a bit rate of 9,000 - 12,000. The output of step 5 had the same 9,000 - 12,000, so that second render did not lower the bit rate beyond what step 2 did.
The lower bit rate results in obvious lower video quality when viewed on my 52" HDTV. It is not as noticeable on my 19" PC monitor, except during pans, where the lower bit rate can result in some artifacts that were not present in the original clips.
The work-around may be a solution for some, but I prefer to preserve the high bit rate and quality by not using transitions and burning the project directly to disc (AVCHD on a standard DVD disc).
