New Info re: AVCHD transition "blips"
michal_h
motherboard: -----
processor: Core i5 520M
ram: 8GB DDR3
Video Card: GeForce GT 330M 1 GB GDDR3
sound_card: -----
Hard_Drive_Capacity: 120 GB SSD
Post by michal_h »
Hello,
I've made a quick test of Corel VideStudio2010 (part of Corel DigitalStudio2010) and I can not see any blips after transition! This version is very simple so I hope next version of videostudio (X3?) will be soon...
Michal
canon hf100
corel VS pro x3
Post by Black Lab »
That is promising news.
mirwais
Post by mirwais »
michal_h wrote:Hello,
Michal
but it doesn't smart-render
michal_h
motherboard: -----
ram: 8GB DDR3
sound_card: -----
Post by michal_h »
Michal
there is no info about smart render during rendring file but it looks some parts (w/o transitions etc) are much faster rendered
I can not see any picture deterioration while comparing original file and rendered file on 50' plasma TV :-)
canon hf100
corel VS pro x3
pwholzel
Post by pwholzel »
I do see picture deterioration in the output of the 2010 product, but I don't see the blips. If you do a cut in the middle of a pan of a landscape (for instance), you will notice that the picture becomes pixelated for a very short instant before and after the cut. It looks like the blips have been replaced by pixelation! Arrgghhh!
Xyzzy2
motherboard: MSI Z77MA-G45
processor: Intel i5-3570K
ram: 8 GB
Video Card: MSI R7770-2PMD1GD5 OC
sound_card: Realtek 892
Hard_Drive_Capacity: 6.25 TB
Monitor/Display Make & Model: HP ZR24w
Post by Xyzzy2 »
Hi!
I've rendered AVCHD to MPEG2 in 2010 and used transitions.
It seems that the blip problem has been solved by another problem- after every transition there is 1-2 frames missing :/
Xyzzy2 wrote:Hi!
You realize that Corel just might correct this missing frame problem, by putting the blips back in, don't you?? ;) :)
pwholzel
Post by pwholzel »
I think I've found a free workaround for the stutters/blips. Please see my post here:
http://forum.corel.com/EN/viewtopic.php?t=36100
pwholzel
Post by pwholzel »
pwholzel wrote:I think I've found a free workaround for the stutters/blips. Please see my post here:
Now that I look closer, I am seeing imperfections. I guess this isn't such a great method.
pitje
Post by pitje »
I am still waiting for a good solution or workaround for this very annoying problem. I worked hours ,to edit a 2H video documentary about the ritual burial in Sulawesi. After rendering ..i saw the disaster !
Is there any news from the Corel side ?
Basic material comes from a Sony HDR-CX105, memorycard, AVCHD files
Nothing heard from Corel on this problem, though they have had it now for about a year. And frankly, I would not be holding my breath for a patch...
The only thing I can suggest in the meantime is something I suggested in another thread, which one user at least found worked. That was not to use transitions as such. Instead, since VS 12/X2 now has this facility, simply drag the beginning of one clip over the end of the preceding one just a little. That automatically madkes it a cross-fade without actually inserting a cross fade transition ... and the blip. That means you are limited to only cross fades and cannot use all the other transitions, but at least you have the most commonly used transition available ... without the blip.
laidback
System_Drive: G
motherboard: Gigabyte - GA-880GM-UD2H
processor: AMD Athlon II 64 Quad Core 4600+ 3.0GHz
ram: 4GB
Video Card: Gigabyte - Nvidia GTS450
sound_card: On board - 7.1 Realtek AC97 Audio
Monitor/Display Make & Model: 60" HD TV via HDMI connection
I Have an Idea.. that may solve this problem..
Post by laidback »
Ken Berry wrote:Nothing heard from Corel on this problem, though they have had it now for about a year. And frankly, I would not be holding my breath for a patch...
The only thing I can suggest in the meantime is something I suggested in another thread, which one user at least found worked. That was not to use transitions as such. Instead, since VS 12/X2 now has this facility, simply drag the beginning of one clip over the end of the preceding one just a little. That automatically makes it a cross-fade without actually inserting a cross fade transition ... and the blip. That means you are limited to only cross fades and cannot use all the other transitions, but at least you have the most commonly used transition available ... without the blip.
On reading this, I think the problem could be the following..
The Transition FX/s may have been designed for 30 fps, and when they are mixed with Pal 25 fps, VS refers from the FX frames to the next clip to the wrong frame after whatever FX has been inserted to the time line..
My other guess would be, the Proxy file used may be 30 frames and also the FX 30 frames, but when the proxy files frame is referred to as to which frame is to be rendered to the Original clip it starts at the wrong place..
If you have contact with Corel, maybe my thoughts should be mentioned to them,
Err~I hope I have nailed this glitch, and if so - I hope corel sends me all there latest Video editors fur fwee! :mrgreen:
Cheerio then Guys N Gals,
Pete..
May The universe return
1000 fold what you give.
BTW - GUYS/Gals, I am Using an AMD Athlon 64 quad Core 3.1 GHz, 4 gigs of memory, GA-880GM-UD2H motherboard, PCIe GTS 450 Graphics, 1 TB sata drive, BluRay Burner.
The only problem with that theory is that if you look at the extremely long thread on the transition glitch (including this one, if you look at the first poster on page 1) you will find that there are NTSC users who also experience the blip problem... :evil:
laidback
System_Drive: G
ram: 4GB
D'oh!
Post by laidback »
Ken Berry wrote:The only problem with that theory is that if you look at the extremely long thread on the transition glitch (including this one, if you look at the first poster on page 1) you will find that there are NTSC users who also experience the blip problem... :evil:
:oops:
Aha! :D So obviously its got nothing to do with the proxy template, nor the frame rates, but I feel it narrows it down to something to do with the FX's..
sorry, if this was mentioned and or suggested earlier, its just that I have a massive memory problem..
Ok I will go over the threads again, and hopefully my stupid short memory of mine wont fail me any further..
Cheers,
Pete..
pwholzel
Post by pwholzel »
FYI, the blips/stutters occur regardless if there is a special effect transition or just a normal cut.
Locked
