I recently created a post regarding rendered video which has some clips increasec in playback speed set to 150% which flicker when shown on a plasma tv.
I replied to that post giving some results of some testing I did earlier and now that post has disappeared.
Where has it gone?
What happened to my post?
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
John a
- jparnold
- ram: 16GB DDR3
Hi Ron.
Yes that's the one.
Problem is
1) It doesn't seem to display on the list of posts.
2) When I display the post using the link you provided it (the post) doesn't include my last post wherein I described at length what I did to test the flickering using rendering using frame based and using lower field first etc etc.
Also that I found that if the playback speed is set to 200% (instead of 150%) the flickering goes away (so it seems that when you INCREASE the playback speed by anything but a multiple of the orginal speed (eg double eg 200%, triple etc) you will probably experience flickering.
Is the 'message board' playing up?
Yes that's the one.
Problem is
John a
