Beginner - I am doing this right? any advice welcome
breadman
motherboard: Dell Inc. 0K216C
processor: 2.40 gigahertz Intel Core2 Duo
ram: 4GB
Video Card: ATI Radeon HD 2400 PRO
Hard_Drive_Capacity: 640GB
Monitor/Display Make & Model: Dell E193FP
Post by breadman »
Hello everybody
OK I said I would put a friend's videotapes on to DVD for viewing on widescreen TV, but am very confused even after reading lots of this forum.
I have used my DVD recorder to record from VCR and produced VOB files.
In Videostudio I have captured the VOB files and to save them I have shared them as mpg. Is that OK so far?
If I put one on timeline, Project Properties show
PAL (25 fps)
MPEG files
24 bits, 704 x 576, 25 fps
Upper Field First
(DVD-PAL), 4:3
Video data rate: Variable (Max. 6300 kbps)
Audio data rate: 256 kbps
What I want to attain (or think I want to attain) is a 16:9 menu and then the clips will have black bands at the sides.
So I then start afresh in Videostudio, do Share, create disk, Add video files (mpgs). At this stage 4:3 is still showing at the bottom. So for widescreen output I switch this to 16:9 and burn.
BUT I'm wondering if after capturing the VOBs I should have chosen 16:9 at that stage and saved them to mpgs presumably with the black bands at the sides.
Would that have had the same result?
And how should I annotate the DVD insert - aspect ratio 4:3 or 16:9 or what ? I don't want to put Widescreen and my friend is disappointed to see the black bands.
Any advice in all this would be greatly appreciated
breadman
Post by Black Lab »
Take a look at forum member Trevor Andrew's advice on working with widescreen.
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
Any 4:3 video will have black side bands when viewed on a wide screen...that cannot be avoided.
You were doing it right the first time.
Set project properties to 16:9 and burn to DVD as 16:9.
This will give you a 16:9 menu and the video will be 16:9 but will appear like 4:3 with black bands on side.
The same DVD watched on a 4:3 screen will have black bands all around (pillar box & letter box).
DVDDoug
Moderator
Post by DVDDoug »
And how should I annotate the DVD insert... I don't want to put Widescreen and my friend is disappointed to see the black bands.
I made a little logo with a square box around it that says:
Full
Screen
And another with a rectangle around it that says::
Widescreen
I would label it "fullscreen"... I doesn't much matter if the black bars are embedded in the video or generated by the TV.
The only time I've tried changing the aspect ratio was when I had a widescreen-letterboxed VHS tape. In that situation, you can end-up with black bars all the way around!
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
Post by Black Lab »
Not so. See Trevor's guide.
