Multi-trim Function not working
Hello,
I am using VS ProX2.
The dialog box opens and I can trim/cut sections of video. But when it comes to save/ok - it freezes.
Since Oct 2008 have reinstall program twice already - same problem.
My operating system is Vista Home premium. Has anyone out there have similar problem?
It works fine in my Ulead VS 11+
VS ProX2 is box and bought online. Box came from Taiwan.
Any suggestion what to do to repair?
Cheers
KimPen
Cheers
KimPen
I had the same problem too. When you click OK button nothing happens. Fix for me is to just hit the enter key on the keyboard. Multi-trim Function will then work.
Yes, forum is experiencing problems, AGAIN!no email notification was in my inbox??
Jeff
Dentler's Dog Training, LLC
Indeed, things seem to be working better today. I won't hold my breath though.
Jeff
Hi hi, after updating DirectX etc... Multi-trim still isn't working by clicking "OK" but........I had the same problem too. When you click OK button nothing happens. Fix for me is to just hit the enter key on the keyboard. Multi-trim Function will then work.
What Nunk recommended works... thankyou NUNK!
Multi-trim
Your welcome KPPang
I think there's bug with on-click event in the Multi-trim dialog box on the ok button . Anyone else have the same problem? If so it should be reported if not already done so.
- solarkritik
- motherboard: h8-1335ez
- processor: INTELi7-3770 CPU 3.40GHz
- ram: 8 GB
- Video Card: AMD RADEON 7570
- sound_card: AMD HighDefinition Device
- Hard_Drive_Capacity: 1000 GB
- Monitor/Display Make & Model: Two monitors: Toshiba and Benq
- Corel programs: VSX9.5 (since July 2016)
I have the same problem with the OK-Button in the "Multi-Trim-Function".
I think the reason of the problem:
If you have more older versions of VS-Software on your PC.
I think the problem can be solved by deinstalling older versions of VS
I'm using "VIDEOSTUDIO" since 2005: using since Ulead 5+6+7 -->> COREL VIDEO STUDIO 10+11+12+14+15+17+19+19.5+20 WIN 10
