Hi Guys
A quick question about Joint Stereo option in x2. It does not seem to work on my mono MPG file. I still only have the left sound channel after rendering the mpeg file using the Joint Stereo option.
I just need to get sound on both channels. Below are the properties of my video file.
File Format: MPEG2
Video
Video Type: MPEG2 Video Upper Field First
Attributes: 24bits, 720x567, 4:3
Frame Rate: 25.000
Data Rate: Variable Bit Rate (Max 8000kbps)
Audio
Audio Type: MPEG Audio Layer 2 Files
Total Samples: 1,009,920 Samples
Attributes: 48000 Hz, 16 Bit, Stereo
Layer: 2
Bit rate 224 kbps
Thanks In Advance
Joint Stereo option not working
"Joint Stereo" may not mean what you think... When you use Joint Stereo to encode an MP3, it doesn't create a mono file... it uses "smarter" compression to combine the information that's common to both channels, so it only has to make one copy of the "center channel" information. When it's decoded, you still have a stereo file.
(I'm not 100% sure that Video Studio uses the same meaning.)
Sorry, I can't help you with the fix. I don't own X2. Is there a "mono" option? A true mono file will play through both channels (or through the center channel on a Dolby Pro Logic system).
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
I thought Joint Stereo option would fill left and right stereo sound track. I fixed the problem now by using different software it would be good if x2 had a new sound filter added to fill left and right tracks.
Hi Tom
Thanks cant believe that was hiding there. I missed it because the option Duplicate Audio Channel is grayed out and x2 is black and gray. So easy to miss for me anyway lol.
It seems to work thanks the lot.
Nunk
Nunk
