Problem:
I've captured files of several VHS movies, aiming to convert them to a DVD. However, to fit them onto a 4.7Gb single layer disc required even a short 86 minute movie to have its scan/burn parameters degraded so that it fitted onto a standard disc. A 105/115minute movie required a lot of degrading. Generally, changing the compression scan rate down was the most effective in reducing required storage space for the resulting movie video.
However, when converting analogue to digital there's an inevitable loss of resolution even with HQ scan and compression rates, and to have to degrade that further to fit onto a DVD disc has the end result of non-linear effects on the resolution of the resulting video, even when viewed on a standard PAL TV.
So I investigated and tried it using a DL (DVD+R) 8.6Gb disc - lots of space on the disc without any change to the quality of the captured files, VS11 will burn it and because its standard spec DVD players will play it.
The video consisted of two captured files - the 1st at 3.9Gb (the file size limit of WinXP based on FAT32) and the second at 2.3Gb. I set them up in a project file and simply burned them without any menu.
When I played the resulting disc on a DVD player, the imagery froze briefly about 20sec (see later comment for how I got that time) before the end of the first clip file, and then played on but reverted to the start of the clip. In testing I haven't been able to determine whether it automatically reverts to the start when playing, or in the rendering and burning process it has rendered the 1st clip twice (despite the default preference setting to play on to the next clip).
I've played the project files in the editor thru transition from the 1st large clip to the second, without any problem. In doing that, I determined time where the freeze and reversion to the start of the clip on the DL disc took place.
I've burnt several 4.7Gb discs with degraded parameters using large clip files and this problem does not occur on a standard disc.
This problem is repeatable on the DVD player, and also using the PC and WinDVD, so it seems to be pretty clear that the problem is generated from the burnt DL disc.
help.
Davidk
