Add audio clip to timeline greyed out!
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
I'm using VS Pro 2. With 'auto music' open and the 'scope box' reading "Owned" I can't upload my selected music clip to the timeline. That option is greyed out. Does this mean I can't use the auto music option withput a further purchase?
Is this perhaps a TBYB (trial) version?....if not continue on....
What that seems is that you did not install the SmartSound Quicktracks or something failed while installing. Is the SmartSound icon grayed out too? If not click on it and go to the Libraries tab. You should see the following:
You may not have some that are depicted in this screenshot.
Go to the About tab and click on the Rebuild Smartsound Database button.
Image.
You can also click on the Folders tab to show where the Smartsound Library files are located on your system.
IF there are no SmartSound Libraries showing, then they must not be installed correctly. You might have to do a repair install.
Post by Trevor Andrew »
If you can play the selected music then Smart Sound is installed.
Make sure the ¡¥Music¡¦ timeline is clear, you cannot insert ¡¥Auto Music¡¦ on top of another sound clip.
You cannot insert Auto Music to an empty project, insert any other clip first.
The auto music will be placed to the curser position.
trevor andrew wrote:Hi
Trevor, yes you can add auto music to an empty timeline, Provided you uncheck the Auto Trim box....
mitchell65
ram: 4Gb
Thanks for all the responses. I have a fully licenced copy and had already gone through the procedure suggested by videoman in the first reply so was sure the sound files were on my HD.
Trevor hit the spot for which, thank you. Then videoman's little extra snippet will be very useful in the future.
This program and this Forum just gets better and better for me. I hope very much to be in a position fairly soon when i can start repaying and possibly help other newbies!
Thanks again :)
vidoman wrote:Trevor, yes you can add auto music to an empty timeline, Provided you uncheck the Auto Trim box....
Thanks for that Ron, its not often that i insert auto music to an empty timeline, and never looked any further.
Cheers
