Help.
Tonight i was using videostudio and it closed off by itself .. i got a warning message..didn't understand it.. so i re-opened it and continued what i was doing.
when i was done i went to save as a video file and it closed off again..
tried again..it closed..
then i went to add a video to the library and it closed with the same message.
i print screened it
http://i44.tinypic.com/skz4he.jpg
help what do i do?
I used version 12 on a dell laptop - vista.
i have NEVER had a problem at all with video studio.
tonight i have not done anything different or my computer has not changed.
why is it doing this?
need MAJOR help. videostudio just closes off... i have pics
ablinkvboxa
Accolades
- motherboard: Gigabyte GA-EX58-UD4
- processor: QuadCore Intel Core i7 920 2833 MHz 21 x 135
- ram: 12 GB DDR3
- Video Card: Nvidia GeForce GTX 295
- sound_card: On Board 5.1 Surround - Realtek ALC888 - 1200
- Hard_Drive_Capacity: 4TB +
Performance Tools for Software Developers
OMP abort: Initializing libguide.lib, but found libguide40.lib already
Symptom(s):
OMP abort: Initializing libguide.lib, but found libguide40.lib already initialized.
This can cause performance degradation.
Set environment variable KMP_DUPLICATE_LIB_OK=TRUE if you want your program to continue in this case.
Cause:
mkl_c.lib is one of mkl static library interface. It defines libguide.lib as a default library for resolution of threading library calls. But other IntelR software such as IntelR IPP, IntelR C++ Compiler and IntelR OpenCV defined libguid40.lib as default. So the error arises because of the duplicate initialization of libguide.lib when using static MKL library and other Intel software at the same time.
Solution:
You could use linker switch /nodefaultlib:libguide.lib and link with libguide40.lib by adding the option to the link line or in project option.
For example, link users.obj mkl_c.lib /nodefaultlib:libguide.lib libguide40.lib. This will stop mkl_c.lib from defining libguide.lib as a default library for resolution of threading library calls.
Symptom(s):
Cause:
Solution:
My You Tube Channel:
My Vimeo Channel:
SONY MOVIE STUDIO PLATINUM HD 10, Corel Video Studio X3, Corel Draw Graphics Suite X4 (Draw, Paint), Adobe Photo Shop CS4, Adobe Bridge CS4, DivX 8, Irfranview, FRAPS, Deamon Tools, VLC, MyDefrag, Nero, AVG, Winamp, Autopano, VMware...
My Vimeo Channel:
Accolades
- ram: 12 GB DDR3
This applies to:
IntelR Math Kernel Library (IntelR MKL) for Windows*
But still have no idea what this means!!!
My Vimeo Channel:
My Vimeo Channel:
ablinkvboxa
Check this thread
Looks like an identical error screen, so follow the steps given.
Good luck, and report back if it works for you!
