This has been happening since I first installed the program and I ignored it for a while, but now it's bugging me!
Whenever I close down Ulead VideoStudio 11 Plus after saving my project, I get an error block that says: Ulead has stopped working. There are then two options: to search for and fix the problem and close, or to close. There is a drop down block under this info and the first line says APPCrash.
It doesn't matter whether I use the exit under File or if I click the X. And then if I want to reopen Ulead, it doesn't open. I have to reboot. At which time it will ask me if I want to recover my project. Even though I carefully saved it and don't need to recover it.
What am I doing wrong or what do I need to do to otherwise fix this?
Thanks.
Ulead has stopped working message block
Clevo
- motherboard: Asus PK5
- processor: Intel Quad CPU Q6600 2.40GHz
- ram: 4GB
- Video Card: NVIDIA GeForce 8600 GTS
- sound_card: Auzentech X-Fi Forte
- Hard_Drive_Capacity: 850GB
Hi fossil...this happens to me occasionally and I just ignor it and then choose to not recover next time I use VS.
This only seems to happen to me when I go do a search on the internet while I have VS running.
I've never been able to eliminate it completely. It is a pain but it's not effecting the project so we have that to be thankful for
Thanks to you both for a response.
It doesn't affect the project, but it's sure a pain to have to reboot if I want to reopen it.
Otherwise, it's a pretty good program.
Also, sorry if I reposted a question from previously! Even though I did a search, I probably didn't word my problem quite correctly.
Thanks again.
Thanks again.
There was a workaround mentioned here that seems to do the trick. Before closing VS make sure you clear the timeline by choosing File>New Project. Whenever I remember to do that I don't have the crashing problem.
Jeff
Dentler's Dog Training, LLC
