Any way to make an AVCHD 720p disc?
mirwais
Post by mirwais »
Hello, I want to make an avchd disc with files that are 1280x720p h2.64 59.940 fps, the only option available is 1440x1080 and 1920x1080, is there a way to 'trick' VS into thinking is compatible so that it doesn't re-enconde, like that tool HDpatch that only works on mpegHD, thanks :lol:
Note: I can make them using other tools, but I want to make a menu and such, thanks again.
Post by Trevor Andrew »
Not sure if this is what your looking for but:-
Using the ¡¥custom¡¦ option
File type Mpeg
Options button.
You can change the frame size to 1280x720 and frame rate to 59.94
mirwais
Post by mirwais »
When I do that, the output changes to mpeg2, not h2.64, and it is greyed out so I can't change it. And my goal is to make avchd disc, and there is no disc option for 720 :cry:
thanks :wink:
