I am new to PSPP X2.
Used freehand selection to copy an object and pasted successfully as a new layer to another image in PSP environment (only the object is showing).
When tried to paste the same to another application such as Epson Print CD, a retangular frame with white background showing as well. What did I do wrong?
Thank you.
PSP x2 copy and paste cropped image
dk4808
David Kwok
Tim Morrison
- Moderator
- motherboard: Asus P4533
- processor: 3.16 GHz
- ram: 2GB
- Video Card: Radeon HD4650
- Hard_Drive_Capacity: 2.6 TB
- Monitor/Display Make & Model: HP LP2275W
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Does Espon Print CD import transparency from images like GIF or PNG? If so you can just paste your selection as a new image and save it to a PNG with transparency turned on.
**File menu -> Export -> PNG Optimizer. Under the transparency tab select Single Color Transparency and use the current layer transparency. Then save **
Then import the image into your program and that should do well.
