Rule of Thirds:
A basic rule of composition is the rule of thirds. This guideline gives you ideas on where to place your subject within the frame. Though your tendency may be to position your subject dead center on the screen, the rule of thirds will give you a more compelling picture.
First, imagine that two vertical and two horizontal lines divide your viewfinder into thirds. (Think of a slightly elongated tic-tac-toe board). The rule of thirds suggests that the main subject in your shot should fall on one of the points where these imaginary lines intersect. The resulting image will be much stronger than if you simply place your subject in the crosshairs.
Lead Room:
Lead room, or look room, is the space that you leave in front of someone's face on the screen. This space gives the person room to breathe, as well as gives the impression that the person is looking at or talking to someone just off screen. If you don't leave enough look room, your subject will appear to be boxed-in and confined.
Be aware that the amount of look room necessary is dependent upon the angle of the subject to the camera. A person looking directly toward the camera will require less look room than someone shot in full profile.
Moving objects such as cars require a similar buffer. Allow extra space in front of a moving car so that the viewer can see that it has someplace to go. Without this visual padding, the car's forward progress will seem impeded.
Headroom is another element you should consider when framing your subject. Headroom is the amount of space between the top of someone's head and the top of the frame. If you leave too much space, the person will appear as if sinking in quicksand. If you don't leave enough room, the person will seem in danger of bumping his head. By positioning the subject's eyes on the top third imaginary line, you will be building in the proper amount of headroom.
More information on these techniques can be found at Videomaker.com.
More: The Divine Proportion: Balancing the Golden Rule
