PAL (25 fps)
MPEG files
24 bits, 720 x 576, 25 fps
Lower Field First
(DVD-PAL), 16:9
LPCM Audio, 48000 Hz, Stereo
these are the project properties of my video and I am trying to convet to MPEG4 for youtube ... not had any problems in the past although not been able to convert via "share" as yet - have down loaded previous vids director through youtube once I have converted the file to mpeg4
Now you have me confused. In your first post you say you successfully converted 6 videos to MPEG4, but now you just said "although not been able to convert via "share" as yet". How, then, did you convert the first 6 videos?
I successfully converted previous vids to mpeg 4 and then downloaded them to youtube direct through youtube
I have tried the share tab to youtube but have not been successful with that option ...
this is the first vid that has not converted successfully to mpeg4 and I cannot see any reason why - it loads up ok and plays ok ... but will not convert?
Ok, so back to the info. You gave the project properties, but what are the properties of the clips you are trying to convert. Right click on a clip and post here.
PAL (25 fps)
MPEG files
Lower Field First
(DVD-PAL), 16:9
If only the new project will not convert then obviously there is something in the project that is causing the problem. Could be a video clip. Are you using audio clips, transitions, video filters, etc? Any of these can be corrupt.
You may have to use trial and error until you find it. For example, let's say the project that is not working is called Project A. Open Project A and delete the first half of it. Now Save As Project B. Open Project A again (this will still be the whole project) and delete the last half of it and Save As Project C. Now open Project B and see if it will render. If not, repeat with the cutting in half and renaming until you can render successfully. You will then narrow down to where the corrupt file is. Repeat with Project C if necessary.
Another option is to remove all the audio clips, then try to render. If it does, great, then you found the problem. If not, remove the transitions, and so on.
I have downloaded AVS Video Converter 6.2 .. tried the trial vrsion and it worked so have paid the £25 and got the full version - just downloadng to youtube now .... will let you know if it works..
