AVC-HD versus HDV editing in X2 Pro
I am looking into buying a HD Camcorder. I am leaning towards the Canon HG20 HD Video Camcorder which records in M2TS format, compressed via AVC-HD.
After reading all the threads, I see a common theme - AVC-HD offers convenience (compared to HDV) but the content is very hard to edit.
Is X2 Pro with all the latest patches a good software package to edit AVC-HD videos?
Has anyone tried the HG20 HD Video Camcorder with X2 Pro?
I am using Vista on a Quad processor and wish to make family videos (consumer level)..
Your opinions are much appreciated, as always.
Neel
Neel
If you read the threads you will see many people have problems either editing or playing back (or both) AVCHD files. Each camcorder manufacturer seems to provide rudimentary software which handles their particular AVCHD files well, but isn't much of an editor.
HDV, on the other hand, seems to get along nicely with most editors, including VS.
Jeff
Dentler's Dog Training, LLC
sherman39
- motherboard: HP 894B 10
- processor: Intei I7-12700
- ram: 16gb
- Video Card: Nvidia RTX 3060 12GB
- Hard_Drive_Capacity: 500GB+1TB
- Corel programs: Video Studio
The other problem with the HG20 (if I have the right camera in mind) is that it uses the new upper limit for AVCHD's bitrate, namely 24 Mbps. This will of course give you great quality. But X2 was written before that new standard was adopted, I am pretty sure, and X2 will probably not be able to handle it at all. I know that I downloaded the sample 24 Mbps file from the Canon website shot with an HG10, but it plays jerkily on my Quad using X2... and remains that way when I edit it and output it using the same settings, and playback in software players capable of playing AVCHD.
mrjohndawson
I am very grateful to Ken and Sherman for their contributions. I too found Corel in the UK in denial over AVCHD problems.
I have a Panasonic SD9. I get all the problems with AVCHD that have been well aired. The "new" patch helped and stopped me abandoning X2 Pro because it is, so frustratingly, close to good (once, as Ken repeats wisely, you have at least Core 2 Duo). But the editing and transition glitch problem still makes Videostudio unuseable for a final product.
When Sherman and others said you can clean the data with AVCHD Upshift and not lose quality as with Nero I wondered. Cleaning video files of intermittent problems has been something present since the early days of editing. And MSP was one of the best I found for cleaning. So here's two cleaning thoughts:
* the Popcorn Media streamer group have found they need to clean some AVCHD data to play and this thread gives links to freeware to do this
http://www.networkedmediatank.com/archi ... -9379.html
* but can Videostudio clean its own AVCHD data? While I have tried AVCHD Upshift, and it was good at converting to mpg2 hd, it lost the 5.1 sound en route. But has anyone actually had problems converting to mpg2 for editing with Videostudio itself and then re-encoding to AVCHD? The Videostudio encoding/re-encoding is fast and seems to fire up optimisation. We need Videostudio's AVCHD to work but is the only downside of this workaround is that it just takes time and more disk space?
I am also thinking about buying the WDTV streamer and wonder if anyone has managed to play AVCHD output from Videostudio on that successfully?
sherman39
- ram: 16gb
Dear John
I have now used VSX2 batch convert to convert AVCHD to HDV and it seems to work well. The only reason I mentioned AVCHD Upshift initially is because in my ignorance (untill a few days ago) I hadn't known that VS could do this.
That said AVCHD Upshift does give the option to vary Keyframes and GOP during the conversion, which may be a good thing. I'm not yet smart enough to understand if these options are worth paying for but thanks to Vidoman who, in another thread, pointed me in the direction of some links that will hopefully help me to understand about GOP.
Regards
Paul
Regards
Paul
mrjohndawson
HDV = uses tape with no problems editing
OR
AVCHD = does not use tape and I need new, powerful computer and still probably have trouble editing and/or playing
Hmmm. When the time comes for me to move to HD I think I'll stick with HDV until somebody figures out AVCHD.
OR
Jeff
As long as you have a quad core PC, it should be fine.Black Lab wrote:AVCHD = does not use tape and I need new, powerful computer and still probably have trouble editing and/or playing
Actually, some software already works very well with AVCHD. And of all things, the free bundled software which comes with Canon camcorder, the Pixela ImageMixer works perfectly with AVCHD. The Pixela AVCHD player can play the video flawlessly, and its ImageMixer can smart render AVCHD clips flawlessly with none of those glitches. If only ImageMixer is not so limited in its editing capability....Hmmm. When the time comes for me to move to HD I think I'll stick with HDV until somebody figures out AVCHD.
That's why it is so disappointing that Corel has not yet been able to fix the X2. Are they even trying? Do I have to look elsewhere soon?
Yes, I know. That is exactly my point. I can edit HDV with the computer I have now. To edit (hopefully) AVCHD I have to spend another $1500+ for a new computer.As long as you have a quad core PC, it should be fine.
Aside from the minimally featured software that comes with the camera, I know of no software (Pinnacle, Sony, etc.) that can perfectly edit AVCHD. Don't lay all the blame on Corel. Much of the blame needs to go to the cam manufacturers for not having a standard form of AVCHD.Actually, some software already works very well with AVCHD. And of all things, the free bundled software which comes with Canon camcorder, the Pixela ImageMixer works perfectly with AVCHD. The Pixela AVCHD player can play the video flawlessly, and its ImageMixer can smart render AVCHD clips flawlessly with none of those glitches. If only ImageMixer is not so limited in its editing capability....
Jeff
