The advanced burner options on the output menu in the burn step are grayed out? How can I activate them?
my o/s is windows xp sp3
Thank you.
ulead picture show 4 burn step output options
drummondrs
Output Options
I'm not an expert on this but since no one else responded, I'll comment at least, based on my own experience. It could be that your problem is specific to an individual slideshow.
I went to burn a DVD the other day and my options were "grayed out" as well. It didn't matter because I was just burning a DVD to be viewed like a movie and I wasn't sending the DVD to someone who also uses the software. Then I went to burn a different DVD and the options were available and were not "grayed out."
I've seen other comments here to the effect that sometimes a slideshow can pick up what I'll call a Gremlin; a bug of sorts. I would suggest you try renaming and resaving your slideshow. Use a unique name and make sure your project is recognized as a DVD (very lower left) and not a VCD. See if that works. If not, you could follow michaeltee's instructions for a clean reinstall.
I hope that helps and keep in mind that I'm just a user like you and an not an expert on this program or computer issue in general.
drummondrs
