unable to burn my project in dvd ulead video studio pro x2
hasbey
Post by hasbey »
I have finished my project, everything perfect till I proceed to record it to a dvd... I confiturate the menus. Everything....When I try to burn to a dvd...I click on next...and nothing happens. What Am I doing wrong?? No error especify. The unique thing that happens is that when I click on next....nothing happens.
My dvd: driver lg gh22ns30
PAL 720*576. 25fr
AL (25 fps)
Archivos MPEG
24 bits, 720 x 576, 25 fps
Lower Field First
(DVD-PAL), 4:3
Velocidad de datos de vídeo: Variable (Máx. 6000 kbps)
Velocidad de datos de audio: 384 kbps
Dolby Digital Audio, 48 kHz, 3/2(L,C,R,SL,SR)
Welcome to the forums,
Sometimes problems with VS such as not advancing to the next step in the burn module or display issues are due to some current updates breaking parts of VS. Go HERE and download the latest MS Direct-X drivers. The most current is dated November 2008.
Do you have Roxio Easy Media Creator Suite, or Nero's InCD installed? These may have installed a Packet Writing utility, that tend to hi-jack DVD burners, not allowing other programs like VS to have access. With Roxio's EMCS, you can internally disable this "drag-n'-drop" utility, however with Nero's InCD you will need to un-install it through the Control Panel's Add/Remove Programs.
Finally when you state you're pressing next and nothing is happening, have you successfully made it to the last (burn) step in the module? If so are pressing the Burn icon located in the lower right of the screen?
