Hi, I am working on a project in which I have to add some arabic text, I have tried with VS 11.5 and VS pro x 2, but it doesn't work, it shows the arabic letters but it doesn't make words ie when you write in english it is from right to left and for the arabic it is from left to right so when i write in arabic it writes the letters in the wrong order, just wondering if there is any support for this language, can anyone help? please. Thank you.
mercedes
Does any VS version support Arabic language ?
What if you write it in, say Word, then paste it into VS?
Jeff
Dentler's Dog Training, LLC
Thank you Black Lab for your reply, I have tried to write it in word and copy and paste, but when you open the text option in VS i can't paste it!Black Lab wrote:What if you write it in, say Word, then paste it into VS?
Does any one know if there is a patch for the Arabic language? as I found in google but I can't be sure if they are genuine.
mercedes
Re: Does any VS version support Arabic language ?
Pardon me if this is a silly suggestion, or if you've already tried it - but could you input your text in reverse?mercedes wrote:Hi, I am working on a project in which I have to add some arabic text, I have tried with VS 11.5 and VS pro x 2, but it doesn't work, it shows the arabic letters but it doesn't make words ie when you write in english it is from right to left and for the arabic it is from left to right so when i write in arabic it writes the letters in the wrong order, just wondering if there is any support for this language, can anyone help? please. Thank you.
mercedes
[/quote]
Pardon me if this is a silly suggestion, or if you've already tried it - but could you input your text in reverse?[/quote]
Hi there, thanks for the suggestion, yes i tried that too but it writes the words as seperate letters not as a joint up word as it should be, which unlike English it will not work you will have to have them joint up to be read properly.
mercedes
mercedes
Do you have any programs on your pc that can properly produce Arabic text?
If you do, perhaps you might have to treat the text as a graphic, and export text from that program to a suitable graphics format. You should certainly be able to output a word-processed document to a pdf file, and may be able to do something with that to convert it to a format suitable for using as an image file in Video Studio.
