X2 Pro Patch and AVCHD
pwholzel
Post by pwholzel »
A number of users have verified that there are blips/stutters even on straight cuts on footage from the hf100. They are difficult to detect unless your shot includes steady panning. Please see the dvinfo forum for more details:
http://www.dvinfo.net/conf/avchd-format ... elp-9.html
Now that I have tested further, I am seeing that the blips/stutters are NOT fixed by this patch, even on simple cuts. So, for now, I will stick with Pixela, which is the hf100 bundled software.
pwholzel
Post by pwholzel »
To show others what I am talking about, I took a short panning clip with the HF100. I used VSX2 and Pixela (hf100 bundled software) to cut the clip in half and simply transpose the second half of the clip with the first. If you look at these files very closely, you will see that the VSX2 file stutters right before and right after the cut between the two halves; the Pixela file does not have a stutter.
For VSX2, I saved the file as AVCHD 1920 by 1080, and accepted all default options.
I've tried many different configurations for VSX2 (turning off smart proxy, using 30p instead of 60i settings in the hf100) and I still get the same stutters on simple cuts. Other folks have tested my source files and have had the same results. I think that a lot of people don't notice this stutter problem because they may not ever cut during a fluid pan.
Here are the two files:
http://rapidshare.com/files/187451333/v ... .m2ts.html
http://rapidshare.com/files/187453468/p ... .m2ts.html
Given that the Pixela files do not have stutter problems, I am sticking with that editing software. I have tried Nero and Power Director, and I have not been satisfied with those applications because they also cannot match the clean output that Pixela produces.
I have tried Vegas, but I don't think my dual core AMD 5400+ is up to snuff. It keeps crashing.
pwholzel
Post by pwholzel »
Here is the source file from the hf100, if anyone wants to play around with it.
http://rapidshare.com/files/187636551/00026.MTS.html
michal_h
motherboard: -----
processor: Core i5 520M
ram: 8GB DDR3
Video Card: GeForce GT 330M 1 GB GDDR3
sound_card: -----
Hard_Drive_Capacity: 120 GB SSD
Post by michal_h »
pwholzel wrote:To show others what I am talking about, I took a short panning clip with the HF100. I used VSX2 and Pixela (hf100 bundled software) to cut the clip in half and simply transpose the second half of the clip with the first. If you look at these files very closely, you will see that the VSX2 file stutters right before and right after the cut between the two halves; the Pixela file does not have a stutter.
hi,
I downloaded your clip created by vsx2 and found out that in win media player the glitch is clearly visible BUT clip checked in Corel frame by frame I can not see any glitches!!! The cut is in time 00:00:05:10 and 00:00:05:11. It is very strange. I will check it on PS3 in the evening...
canon hf100
corel VS pro x3
2Dogs
Post by 2Dogs »
michal_h wrote:I downloaded your clip created by vsx2 and found out that in win media player the glitch is clearly visible BUT clip checked in Corel frame by frame I can not see any glitches!!! The cut is in time 00:00:05:10 and 00:00:05:11. It is very strange. I will check it on PS3 in the evening...
The same used to be true with glitches in smart-rendered mpeg2 clips. If you stepped thru them frame by frame in VS, everything looked fine, but on DVD's played back either on a pc or set-top/standalone player hooked up to a tv, you could detect a brief flicker.
When you checked the clip in something like Virtual Dub, you could see clear anomalies at the transitions.
It's a while since I checked this effect in mpeg2 editing - I think I looked at the problem with VS8 or 9.
pwholzel
Post by pwholzel »
Michael, did you notice the stutters when you viewed the file on your PS3?
michal_h
motherboard: -----
ram: 8GB DDR3
sound_card: -----
Post by michal_h »
pwholzel wrote:Michael, did you notice the stutters when you viewed the file on your PS3?
unfortunately yes I can see the glitch on ps3
canon hf100
corel VS pro x3
Doctor Keo
motherboard: Packard Bell BV M2NS-NVM 1.XX
processor: 2.00 gigahertz AMD Athlon 64 X2 Dual Core
ram: 4GB
Video Card: Nvidai 8500GT
Hard_Drive_Capacity: 750GB
Post by Doctor Keo »
Hi, I¡¦m experiencing problems with VS X2 Pro with AVCHD 1080i (HA1920 ¡V 17mbps VBR) video produced by a Panasonic HDC-SD9. I have installed the latest patches and have glitches in the frames before and after transitions and edit cuts. I¡¦ve now spent weeks on trying to produce a satisfactory file output. I have tried most quality settings in the hope that just one would not have the frame problems. I spoken to Corel Tech support in the UK some 25 times, Corel (The techie ) denies that VS has any problems with AVCHD ¡V And as there isn¡¦t a problem refuse to suggest any solution! I have found work rounds, the first I tried AVCHD Upshift ¡V As my copy is only a trial it limited the clips to 10 seconds, but importing the processed clips into VS doesn¡¦t seem to experience the frame problems with transitions or edits. My second solution is processing the source AVCHD through Nero Vision 8 and outputted a HD file at 1080i, 17 mbps and used this as a source to VS. My test output file to AVCHD on DVD played OK on my PS3. I¡¦m now trying some 20 minutes onto AVCHD DVD disk. The only down side I¡¦ve found is that I lost the 5.1 sound from the original video and as the video wasn¡¦t shot in the best conditions is difficult to judge the final output.
pwholzel
Post by pwholzel »
Thanks for the tips, Doctor. I tried Nero-VSX2 and I noticed quality loss. I haven't tried AVCHD upshift, but I think I will just stick with Pixela for now, as it guarantees the best quality with the fewest headaches. Unfortunately, Pixela is very limited in terms of editing capabilities.
