I been expiermenting with VS X2; since I now see alot of pixelating. If I take any two short video clips (AVCHD) and place in the timelime. Set my file output to, AVCHD file (1440x1080); 15000 - 18000 VBR; The program will render fast; while doing the first clip. Once it reaches the second clip,
I see the rendering percent slow down. After the video file is made; (H264 AVC). The first clip looks great, on the player; no pixels, VBR aronud 11,000 - 12,000. When the second clip comes on, pixeling; and the rate drops to 6,000-8,000 avg. After trying a few things, I made another file, with one clip; but in the middle of the clip, I added a small fast text, in the text timeline. Sure enough, rendering was fast, until it reached the text. The resulting video showed the same. Video was great, until the text, then the VBR dropped to around 6000; for the rest of the clip. I added the latest patch, but to no avail. It seems that anything added to the first video clip; decreases the VBR rate, for the rest of the project. I also tried doing this, direct to the disc. Result... First clip okay High bitrate; second clip? Same problem, bitrate drops. It looks like the MPG maximizer, might be the problem, kicking in, but not out. Tried saving as; Blu-ray files too. With the maximizer, same thing. Without the maximizer, I get a MPG2 file with max bitrate. I hope there is a answer to this.
AVCHD disc encoding bug?
richmg821
- motherboard: Asus M4A785M
- processor: AMD Phenom II X4 940 BED
- ram: 4GB
- Video Card: ATI Radeon HD4800 1GB
- sound_card: Delta 1010LT
- Hard_Drive_Capacity: 3 TB
- Monitor/Display Make & Model: Samsung P2770
Clevo
- motherboard: Asus PK5
- processor: Intel Quad CPU Q6600 2.40GHz
- ram: 4GB
- Video Card: NVIDIA GeForce 8600 GTS
- sound_card: Auzentech X-Fi Forte
- Hard_Drive_Capacity: 850GB
Interesting...
So the two clips are identical in every way?
Try this...with the first clip, put it in the library then drag down a copy intot the timeline so you have two copies of the first clip that renders fast... try rendering again and see if it goes through both clips very fast... if it does, We can conclude that there may be something wrong with your original second video clip
You mention a patch. There is no patch for VSx2. You probably meant something else but I am not sure. Can you clarify what you meant?
richmg821
- ram: 4GB
Bug
If you go to Corel.com; go to upgrades. It's hard to get to; but with some searching go here:
http://www.corel.com/servlet/Satellite/ ... 7911963266
Click on VS studio 11/11+; a small window will show up on the next page; scroll until you see Video X2. It changed my X2 to: example; VS12.0099.0 to like 12.0099.1
I found it not easy to find; like Corel was sort of hiding; there was a update to X2.
As I put further down; I could put a single video in the time line, and insert a title; and after the title.. Same thing. I swapped the positions of both videos; same result. Used the same video twice. Once the VBR; and rendering slows down, it never recovers. Same with using direct AVCHD to DVD.
richmg821
- ram: 4GB
X2 Update
Oops sorry;
This is the page. Left off a few numbers.
Click on VS 11/11+ then scroll in that litlle product window for X2.
There should have been a VS12 to click on too. It was just curiosity; I clicked on VS11
Re the update patch, the link you provide took me to a page saying that the page I was after does not exist. So I did a bit more sleuthing. The Corel update page does not show any update for X2. But after chasing a couple more links I found -- very much to my surprise -- that indeed there *is* an update patch for X2 and moreover it is dated November 2008! It can be found at http://www.corel.com/servlet/Satellite/ ... 9440480826
It is 18.6 MB and the blurb says the following:
Needless to say, I am currently downloading it!
Most fascinating to me (particularly as an Administrator who was till just now totally unaware of this update! Thanks Corel!) are the claims that writing HDV projects (I assume back to camera, since this was the only problem) has been fixed and AVCHD performance has been enhanced.November 2008
To provide our customers with the best possible product performance, Corel is pleased to release the following update to Corel VideoStudio Pro X2:
Compatibility Improvements:
* K-Lite codec pack now works properly when creating FLV files
* Program now successfully converts JVC® GZ HD-30 files
* JVC GZ HD-30 files now import correctly
* MP4 file insertion now works as expected
* Program now successfully plays clips captured by Sanyo CG65
* Files captured by Samsung NV24HD can now be imported correctly
* HDV now writes edited projects correctly
* H.264(MPEG-TS) Audio now plays correctly
* AverMedia volar MTV H.264 MPEG-4 files are now inserted as expected
* H.264 file playback performance for AVCHD™ clips is enhanced
* Program now includes support for Kworld USB capture device
User Experience Improvements
* Imported DVD subtitles are now clearer
* Painting Creator playback performance is enhanced
* Some special characters no longer cause template errors in Spanish version
* Movie Wizard Template errors are corrected
What is the purpose of registering your product if they can't even send a measly email telling us a patch is available?
Jeff
Dentler's Dog Training, LLC
I've installed it and have been doing a little experimentation with its effect on AVCHD editing. See http://forum.corel.com/EN/viewtopic.php?p=175196#175196
Mixed results, though generally quite positive for at least some AVCHD users...
