Cant Preview for DVD
Posted: Fri Jan 09, 2009 6:04 am
by extremekicks
When I create my menu I cant preview it. I downloaded and applied directx9, rebooted and confirmed with run>dxdiag.
Any info would be apperciated to get this function to work.
Sincerely,
B
Bummer
Posted: Fri Jan 09, 2009 7:10 am
by 2Dogs
The DirectX update seems to solve the preview problem most of the time.
Do you have a downloaded version, or the full boxed retail version?
If the latter, you might try a repair install, otherwise maybe just try re-installing. Disconnect from the net and shut down your firewall and AV programs when you do the install, that might help, since they've had to become pretty aggressive in the last few years.
Fill in the pc related stuff in your profile too, to avoid having to repeat what kind of system your running.
Posted: Fri Jan 09, 2009 3:23 pm
I had a similar problem a while ago. DirectX did not solve it. I reinstalled VS and did a System Restore, one of which fixed the problem.
Posted: Sat Jan 10, 2009 3:59 pm
by extremekicks
Ok I was able to get the preview to finally work. I had to run the program to verify the active X I totally wipped my system prior to errors I was getting in another post. And all along it was a bad battery.
Things are good now and I'm looking forward to X2.
B
