Recently I upgraded my PC. The drive I had previous video and audio clips on has a new name so now the MANY clips I had in my library from another large project have to be relinked.
I can't rename that drive to match what it once was because I now have just as many new clips in the library from a more current project. I know, DUH! Should have figured this out before starting the new project.
So, is there a way to relink several clips at one time or am I stuck doing this to each file one at a time.
I'm afraid I won't like the answer.
Thanks!
"Batch" relink library files?
westlight
- motherboard: ASRock 970 Extreme3
- processor: AMD FX-6100 Six Core Processor 4.20 Ghz
- ram: 16 GB
- Video Card: AMD Radeon HD 6700 Series
- Hard_Drive_Capacity: 8000 gb
westlight
www.westlight.net
www.westlight.net
Yes be afraid, be very afraid....
Most of the time, when you have a project that contains moved files, just re-linking 1 or 2 will be sufficient, provided that all the clips in the project timeline are located in the same new folder.
However the Libraries are totally different. I'm afraid that you're instinct is correct. You will need to relink each one..
