Burn After Reading
tjd
Burn After Reading
Post by tjd »
So here's the deal: I made a disc image file, but when I see it in Explorer it looks like it's in two parts: a Zip file and a MS Access file.
Is it extensions confusion?
Also, what files to do I burn to a disc? Here are the disc image files indicated by my system:
PRJ_20081231 182,400KB WinZip
PRJ_10081231.iso 1KB
What gets burned to the disk?
Post by Trevor Andrew »
Change the explorer view to 'details'
The one you burn is the **************.iso
If you use the VCD/DVD VR disc image recorder, then only the correct file will be seen.
The file size is a bit confusing.
tjd
Post by tjd »
OK, thanks Trevor. I'll give 'er a try and let you know.
