Unable to change input sources.
Posted: Fri Jan 02, 2009 2:33 am
by FZeroRacer
Hello all, I have been having the hardest of time trying to set up my easycap (yeah...yeah) and through various hardships, I did manage to get drivers working, somewhat. I am currently on Vista x64 and the drivers I used are the following:
http://www.gizmograbber.com/upload1/200 ... 064bit.rar
Using these was the only way I could get it to detect the correct drivers and actually install them.
Now then, when I attempt to use videostudio to record, I get no video. Many of the fixes i've seen for this is to change your input sources, however the box is grayed out and unable to be changed. When I head into capture properties -> video capture filler, I get the following error:
"Calling syntek mini-driver "get" error" or some such. I assume this is a result of installing the wrong drivers, but other vista users report that it works.
This probably isn't exactly videostudio related, but I have been scouring the internet to no avail. I would love to get this thing working.
Posted: Fri Jan 02, 2009 4:51 am
by Clevo
You are close to admitting you have installed the incorrect drivers (if I read you correctly) yet you wonder why it isn;t working properly.
Vista 64 bit requires 64 bit drivers...check the manufacturers website for the latest drivers
Posted: Fri Jan 02, 2009 4:56 am
by FZeroRacer
Clevo wrote:You are close to admitting you have installed the incorrect drivers (if I read you correctly) yet you wonder why it isn;t working properly.
That's the problem, those ARE the 64 bit drivers. They are the only drivers that easycap will actually find and install. At least, the only drivers I can find after trying various others.
Posted: Fri Jan 02, 2009 5:30 am
by Clevo
FZeroRacer wrote:Clevo wrote:You are close to admitting you have installed the incorrect drivers (if I read you correctly) yet you wonder why it isn;t working properly.
hmmm OK
What model easy cap is it?
Posted: Fri Jan 02, 2009 6:42 am
by FZeroRacer
Clevo wrote:FZeroRacer wrote:Clevo wrote:You are close to admitting you have installed the incorrect drivers (if I read you correctly) yet you wonder why it isn;t working properly.
hmmm OK
DC60.
Posted: Fri Jan 02, 2009 7:21 am
by Clevo
I cannot guarantee this will work for you. I found this via google:
http://www.digital-devices.co.uk/downloads.php
Let us know how you go...it seems you are not the only one with this sort of problem with the easy cap 64bit drivers...
Posted: Fri Jan 02, 2009 10:11 am
by FZeroRacer
Clevo wrote:I cannot guarantee this will work for you. I found this via google:
'Fraid those are some of the drivers I tried before. I have about five different sets of drivers, and the only ones that work are the ones in the first post. I tried uninstalling my drivers, reinstalling, attempting various different drivers and so forth.
So far the only thing I can come up with is that the syntek mini driver "get" error refers to the mini-driver files inside the x64 folder in the original .rar pack. The x84 parts do not matter and can be deleted with no change, but the x64 parts can not. I had thought maybe they weren't getting installed correctly (tried moving them to the main folder) but that didn't work.
To add a bit more info too, when I connect my 360 to easycap, I get no video using the yellow to yellow cable, but I get gray lines when I hook in the green cable. This still doesn't help much though as, said before, I am unable to change the input settings.
Hrm.
Posted: Sun Jan 04, 2009 5:22 am
by FZeroRacer
Hm. If easycap won't work, are there any ideas for good alternatives that work on vista x64?
