How can you start the sound from a clip but leave the screen black and slowly fade in the video from the clip. Sort of like a dramatic entrance that you might see in a movie. While the opening title scenes are playing the sound starts playing for maybe 10 seconds before the video portion comes in.
Thanks!
Starting the Sound Before The Video?
What you're referring to is called a J-cut. Doing the same at the end would be called an L-cut. A tutorial was written for this technique using VS9. The same still works with the more current versions...
J and L cuts
J and L cuts
Using the ¡¥overlay track¡¦ you can insert a colour clip from the library.
Set the duration for 10 seconds
With the clip selected , right click the preview screen and select ¡¥fit to screen¡¦
The top track will be covered in black.
Using the fade out option will fade the black to reveal the top track.
The fade defaults to 1/3 of the length of the clip.
