Fade out clip
Fade out clip
I understand how to do transitions between clips. I'm trying to have an ending clip fade to black and have a title fade in. I can make a title fade in from black but I'm not sure how to make a flip fade to black without having another clip to transition to.
Unless your clip is in an overlay track that has it's own Fade-in/Fade-out, you have to use a color clip (black), with a fade-out transition.
However there is a sneaky way around this...Use the Pan/Zoom filter. It has a transparency option that could be used as a Fade-In and Fade-Out.
- Drag the pan/zoom filter to your clip.
- Click on the Customize button.
- On the first Keyframe, set the Zoom to 100%, and click on the center box to anchor it to the center of the frame.
- Right-click on the First Keyframe and select Copy/Paste to all.
- Go to the end of your clip, then move the playhead back about 1-2 secs.
- Right-click on the Filter's timeline, and select Insert to insert a keyframe. Don't change anything here.
- Go to the last keyframe, and then move the Transparency slider all the way to 100%.
Bob Hughes
- motherboard: Dell Inc. 0Y2MRG A01
- processor: 3.40 gigahertz Intel Core i7-2600
- Hard_Drive_Capacity: 1.5 TB
Great idea. I never thought of that. One thing though, using 11 +
I'm not sure about cut & past, but if you move the slider to where you want it to start to fade & click on the + symbol another point is created. You can set this to 0 transparency. Actually you can create several points & set transparency or zoom to what ever you want.
I just discovered this myself.
Bob
Bob
Bob Hughes
You shouldn't have to make one black, as there is already one included in the Color Library. To access the Color Library, click on the down-arrow beside what is the Default Library showing--Video. Then you should see it in the menu choices. There are several colors provided. Just select the black one, drag and drop it in the timeline.
