SF2MJ wrote:Amd Athlon 64x Dual core processor 4000+ ,MMX,3Dnow (2cpu)
Ram 894
Graphics ATI Radeon Express 320 mg
Directx 9.0c
I have 17gb free space on c drive right now...and 18gb free on D drive
And I presume you are running Windows XP.
Nothing wrong with your pc spec.
If your are running Vista, 1Gb of RAM might be considered marginal though it shouldn't be the cause of your blurry problem. With XP, 1Gb is definitely fine. 894 (Mb) is an odd sort of RAM number - though maybe your onboard graphics are sharing RAM and using up 130Mb.
You don't have a lot of hard drive space, though since you already captured the DV avi video, the 13Gb or so it takes up will already be on the hard drive.
Did you keep or delete the DV avi file you created from your project as one of Graham Skier-Hughes' suggested things to try? That file, if 75 minutes long, would amount to over 16Gb.
Is the D: drive another internal drive, or perhaps a partition on an internal drive, or is it an external drive? If it is an external drive, and you had VS output mpeg files to it, you might try some test output to the C: drive to rule out any hard drive data tansfer rate problems.
You could try downloading and running the freeware Sisoft Sandra Lite program, a 17.2Mb download, which you can use to check out your pc setup.
http://download.softpedia.com/dl/ad29ea ... an1572.exe
