vstudio.exe Application error
extremekicks
Gang I was trying to create a DVD and kaboom. My PC crashed.
Now when I try and open my VS11 PLUS I get the following error.
"The Application failed to initalize properly (0xc015004). Click on OK to terminate the application.
Helppppppppppppppppp.
Brian
Brian
extremekicks
extremekicks
extremekicks
vidoman thanks.
I guess I will dump them although I do dump alot of my event video but didnt know the VSP file would take.
I wonder if going to XP SP3 did any of this?
Also how should I go about installingVS 11plus any order?
I have...
1.VideoStudio11Plus-E-Download
2.VideoStudio11Plus-E-ContentPack
3.VideoStudio11Plus-E-BonusCD
4.UVS11_Plus_ESD_ENG_PowerPack
Also does the new Pro X2 program have more bells and whistles then VS11?
Any info would be apperciated.
B
I have...
B
You install them basically in the order you have, except the Bonus Material does not install, it is just copy/paste stuff, like sample video, image and audio clips, IIRC (if I recall correctly).
There is also an Update Patch for VS 11 plus that should be installed before installing the Power Pack. The Power Pack upgrades you from 11.0 Plus to 11.5 Plus.
It has a few more, such as the Painting on Video, and the ability to use transitions in the overlay tracks..
Before you install the Power Pack (dated 8 November 2007), you need first to install the update patch dated 6 November 2007. Otherwise, that is the order you use.
And yes, X2 Pro has a few more bells and whistles which many of us think make it worthwhile to upgrade. These include transitions in the overlay tracks, some very useful new filters, and more menu templates to name a few.
EDIT: You beat me, Ron!!!
extremekicks
Looks to me like a problem with the Raid controller or one of the discs.extremekicks wrote:IO_WARNING_PAGING_FAILURE ( Disk warning)
viamraid did not respond within the timeout period.
I think it may be a hardware failure. Raid is known to be more demanding on hard drives. Unless I thought I'd get a real benefit from it, say if I was a serious gamer, I wouldn't use it.extremekicks wrote:I think its the OS and VS both. Ugh
extremekicks
extremekicks
extremekicks
extremekicks
Ok heres what happened.
Since I had RAID set up I was getting those errors...right?
I went and installed basic XP pro with no RAID.
Did a graphics test and bam it did it again. However there were no errors on the event viewer.
So I was closely listening and watchin my system, noticed the Power supply fan lagged a bit. Replaced the Power supply and ran a graphics test and passed with flying colors no shut down.
Well im in the middle of installin VS 11+ and I'll be back with more updates. Whew what a PITA.
extremekicks
