upgrading to vs x2 or pro
Can you bring a vs10 project into vs x2 timeline and then continue editing? Another words are they compatible as far as the saved projects go?
I assume you are talking about custom libraries?
You can copy the libraries from v11 then past them back into v12. The library files you need to copy are:
Video = VS_Video.dat
Audio = VS_Audio.dat
Images = VS_Image.dat
(The same format applies to titles, flash, colors, etc.)
They can be found in C:\Documents and Settings\User Name\Application Data\Ulead Systems\Ulead VideoStudio\11.0
Jeff
Dentler's Dog Training, LLC
For Vista machines, those library files are located:
Local Disk (C: )\Users\YourUserName\AppData\Roaming\Ulead Systems\Ulead VideoStudio 11.0
Vista replaced the Documents & Settings with Users folder, shortened the name from Application Data to just AppData, and has the Roaming folder.
Note there are 3 folders under Users; Local, Local Low, and Roaming. The files you need to backup are found under the Roaming folder.
Good catch Ron.
Jeff
